Results 1 to 8 of 8
Thread: AK engine into mk1
    May 2015
    Brisbane Queensland
    AK engine into mk1
    has anyone done a 2.0 mk4 engine into a mk1?
    Feb 2013
    Melbourne SE
    I imagine it would be the same as a 1.8t in terms of mounts and that, but others would know better.
    My question is why? Mk3 2.0 engines are everywhere and mk1 mounts bolt straight up. You can even fit mk4 heads with a little modification. Does the AK have an aluminum block?
    burnie,tas
    Quote Originally Posted by Browneye View Post
    Sorry for pitching post but I got a 2e in mine and searching for bit more go what's this bout mk4 heads, 16v?
    1977 2dr golf gls (Gti look a like with 2e convertion
    1978 Golf Gti barn find
    2013 Amarok Highline daily
    2017 Golf wagon wife’s daily
    Feb 2007
    ^ At a guess I would think Browneye might be talking about a 2lt cross-flow head from the Mk4 (rather than the counter-flow ones that come as standard on engines like the 2E).
    Mk3.Mk4.Mk1
    My Mk1 Project
    burnie,tas
    Thanks is that a 8 v or 16v
    Feb 2013
    Melbourne SE
    Quote Originally Posted by hazards_golf74 View Post
    Sorry for the confusion. 8v mk4 heads can be put on external water pump blocks but they require welding and machining so that the oil returns line up with the block. Same goes for 20v heads and I assume 16v heads. They both lower the compression to around 8:1 so would need boost or custom pistons.
    Would be easier to put the whole mk4 lump in using off the shelf custom mounts (assuming they're the same as 1.8t blocks). Probably worth a shot. Haven't seen it done personally and would give a mk1 a nice kick up the ass. Not sure how much more than a mk3 2.0 would though.
    Feb 2009
    Please Enter Location
    1.8 Turbo is the best and easiest upgrade in the long run.
    Nothing is cheap really.
    As yours is already fi ABF out of a Cupra would be 2nd choice.
    8 v upgrades are not cheap really and only produce small improvement.
    burnie,tas
    Thanks for your help, got some thinking to do
