Results 1 to 7 of 7
Thread: VW Polo Water pump
    Feb 2020
    Gladstone, Queensland
    VW Polo Water pump
    Hey guys. So i've had my water pump crap itself. Went to VW and was quoted $900 just for the part, which is steep. Tried to find a non genuine part, problem is everywhere is showing a different part. Supercheap auto and repco websites have like 3 different pumps, and i don't know which one it actually is. Anyone have any suggestions?
    Car is a 2012 VW Polo GTI 1.4TSI
    Yeah I wouldnt go to Repco or Supercheap for anything like this unless you have a super common car like a Camry or Falcon etc.
    RunAutoParts is where I get a lot of my parts and filter etc and they only deal with European car parts. They are saying this is the part # for a 2012 Polo GTI 1.4 water pump.
    TOPRAN Water Pump 113 791
    2017 Ford Fiesta ST
    Feb 2020
    Legend, thanks mate. I just purchased it for $350 off there, $550 cheaper than VW
    Quote Originally Posted by Reecy123 View Post
    Better in your pocket than VW's pocket.
    2017 Ford Fiesta ST
    Jul 2020
    Queensland
    Good to know!
    Did you replace the pump by yourself?
    How did you go?
    Do you need a torque wrench to put it back?
    How did you go?
    Thank you
    Feb 2010
    Safety Bay, WA
    Quote Originally Posted by LFO View Post
    How did you go?
    I did the pump on our Gti, got a Quinton Hazel replacement from Mick's Auto Parts in Ireland for $310
    It's a pain in the arse job to do. Numerous pipes, belts, covers and even an engine mount needs to be removed.
    You don't need a torque wrench, but you need a combination of:
    Jack
    Axle stands
    Phillips screwdriver
    Metric socket set
    Torx set
    Double inhex set
    Vagcom cable to relearn the clutch on the pump pulley.
    It's a job best done by someone else.
    2012 Polo GTI (and 15 other cars in various states of disassembly)
    Jul 2020
    Queensland
    Thank you for your detailed response.
    Yes, I agree it looks like a job best done by someone else!
    I found a YouTube showing some of the process, not very good but it shows the steps: VW Polo water pump and thermostat housing replacement - VOLKSWAGEN - YouTube
    What is the "Vagcom cable to relearn the clutch on the pump pulley" for? The video seems to just tension the belt with torque wrench. A bit of a guess as they don't actually show any detail.
    Still undecided on how I will go. The local VW "stealership" quoted $1,050 all included.
    Pump itself from OEM is around $220.
    I already bought a VW G13 coolant (~$50!!) to top up now and then.
    Maybe I will just keep a watchful eye and refill as needed ... and procrastinate on what to do !!
    Thank you again.
