Results 1 to 7 of 7
Thread: how to jack up the front and rear of the car
    Apr 2012
    Bridgeman Downs ,Brisbane
    hey guys, pretty noob question but
    so im looking to jack up both rear wheels and both front wheels.
    where underneath the car should i place the jack or do i have to do each corner at a time
    and yes i will use axle stands and im buying a hydraulic jack
    manual just says to use the jack points on each corner
    Jack the front of the car up first using the jack points which are pretty much where your front guards end and your doors start.
    Once the front is up and safely resting on some axle stands, then raise the rear.
    Apr 2012
    thats what i thought, so i have to do one corner of the car at a time?
    Jun 2008
    Ringwood, Victoria
    The front you can use the subframe crossmember, this will lift the front evenly so you can get your stands under the liftin points. The rear unfortunately requires you to lift each side separately.
    Apr 2012
    Will using the jack points on these with a hydraulic jack result in folding over the crimping of the unibody? I've seen lots of (japanese) cars where this has happened.
    On the rear, I've gone under the spring perches with a hydraulic jack, but, one side at a time....
    Apr 2012
    Yeh I'm pondering that aswell ? I'd say it would
