Results 1 to 4 of 4
Thread: Oil Seep / Leak from PCV Valves and Wastegate Rattle - 6R TSI
    sydney
    hello there
    i noticed some leaks during a recent service, i think they are coming from the PCV valves (are these the PCV valves) - possibly the units need replacing or the seals on these units. has anybody had anything similar? can anybody confirm these are the PCV valves? pictures below.
    also, i think i finally diagnosed the rattle when accelerating under certain conditions. especially noticeable at very low speed manoeuvres (on and off the clutch making small movements of the vehicle e.g. when parking) - it's coming from the wastegate area. then i discovered it's well documented, doh! going to give the following part a go and see whether the rattle stops:
    403 Forbidden
    if anybody has any comments / experiences to share it would be much appreciated.
    thanks
    Oil Seep / Leak from PCV Valves and Wastegate Rattle - 6R TSI-alzblckqgpojlw9b5nakergd93_mc_muopzotcmnkwzj-jpg
    Oil Seep / Leak from PCV Valves and Wastegate Rattle - 6R TSI-avbuyznlfxbtrxkppw1zxx5gm91k76mhgtusn0aa7erl-jpg
    Oil Seep / Leak from PCV Valves and Wastegate Rattle - 6R TSI-amwxm-lla08888fcabaoscwgjhkjg3bdihyt9yvlj3wz-jpg
    Oil Seep / Leak from PCV Valves and Wastegate Rattle - 6R TSI-asz9im5bx05orhuedehnmthnzvmg3jun0qpeug5kwz9m-jpg
    That wastegate clip you have linked to is for the 2.0TSI engine - it will not fit your Polo engine. They use a type of spacer/washer on the Polo's to fix the turbo rattle. Your dealer should be able to sell you the part.
    Jun 2008
    Emerald, Vic
    Oil smell in cabin
    I had this happen to mine, looks similar?
    My Car(s): 2011 6R TSI Comfortline (Pepper Silver),
    If you're in need of any 6n1 parts, odds are that I am going to have them (dismantling 2 at the moment)
    sydney
    thanks for both of your replies gents
