Results 1 to 10 of 15
Thread: DSG reving high when keeping speed going down hill. Normal?
    Sep 2009
    WA
    Blog Entries
    1
    Question DSG reving high when keeping speed going down hill. Normal?
    Wondering if this is normal: when I drive the new Polo and I come to a steep hill, when using the break to keep the (60km/h) speed limit, the gearbox kicks down to 3rd gear and revs over 3000rpm. Before I put my foot in the break to keep speed it's in gear 6 or 7 and then kicks down to 3.
    Normal?
    VW Tiguan 2018 162TSI Highline
    VW Polo 2015 81TSI Comfortline
    Oct 2010
    Melbourne, VIC
    Absolutely normal. It's interpreting that you want to maintain your speed so it shifts down to help. It gets it right a surprising amount of the time
    Resident grumpy old fart
    Dec 2008
    Sydney/Canberra
    Engine braking.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Sep 2009
    WA
    Blog Entries
    1
    I don't notice this on my s-tronic Audi A4, but maybe it's more subtitle given its a higher end car?
    Oct 2010
    Melbourne, VIC
    The programming will be completely different for the larger engine which will provide more engine braking as well as "normal" power and torque
    Dec 2014
    New Zealand
    Try not releasing the brake pedal completely while going downhill, just gently modulate. Certainly it downshifts the second time I touch the pedal without using the gas pedal in between. Our 2004 BMW does the same thing and it can be annoying when you want to coast a bit. I have to briefly tap the gas to get it to upshift.
    Erskineville, NSW
    Maybe rather than use the brake, anticipate that you are going down hill & back off a fraction earlier & use the gearbox rather than brake?
    Apr 2010
    Or use tiptronic to select the hear you want. The manual recommends 3rd gear for steep declines and general advice is not to ride brakes for an extended period of time (ie down a mountain).
    Oct 2010
    Melbourne, VIC
    I really don't think the OP is complaining about the car slowing down too much but is just querying the gearbox behaviour.
    Oct 2011
    South Australia
    Quote Originally Posted by anonymousmoose View Post
    Normal?
    Completely normal. My polo gti did it my new golf gti does it....my mk5 tdi didn't. So newer dsg engine combos are programmed to use engine braking as much as possible i think.
