Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Where to purchase a down pipe?
    Feb 2015
    Auckland, New Zealand
    Hi team, time to start looking at down pipe options.
    If I'm not mistaken Milltek are the preferred item? Open to suggestions, and experience.
    Also where to purchase one from a company that will send to New Zealand?
    TIA.
    nsw
    I you want to take things a fair way with mods then I'd suggest 3in dump and whatever size back section you can afford/tolerate noise wise. Only drama with that avenue is that it is a size that isn't retailed. It'll have to be custom made, but you can split the cost by doing a custom dump/cat and flanging it for a retail 2.5in cat back i you wanted.
    If you don't think you'll go nuts then 2.5in will probably be fine (just atleast try to get 200cell or less cat so you can make the most of it).
    Both will need either a phase/stage 2 tune to tick off the cat eficiency code in the software that any dump pipe will likely generate OR you can run a second O2 sensor spacer to mechanically trick the ECU into thinking that flows in/around the cat are normal. Not sure how this would perform on a stock tune (bit strange apparently) but it goes like a demon on my phase 1 custom code with a few tricks.
    Oh and in NZ you may or may not have to run a cat. That makes the custom dump cheaper and the milltek 2.5in substantially so.
    Quote Originally Posted by amdeman View Post
    TIA.
    I don't think you'll find much off the shelf except Milltek. Look for stuff that fits the Seat Ibiza as well. Might open some Euro doors.
    nsw
    supersprint do a 2.5in but it has a different solution to the usual flex joint. They do catless ones too.
    Feb 2014
    Gold Coast, Queensland
    From personal experience I vote going a 3" downpipe straight away. Get it custom fabricated, cost wise over 2.5" it won't be much more, and saves doubling up like I did if you decide to go for more power down the road. Noise wise the 3" is hardly noticeable over the 2.5" with the stock catback as well. Just my 2 cents
    2006 GTI Polo - Big Turbo Build - Louis19's Build Thread
    Dec 2014
    coopers plains, QLD
    Magnaflow have a 3" and mettalic cat slipfit for 430 plus GST
    Quote Originally Posted by elcono View Post
    For a Polo GTI?
    Feb 2015
    Quote Originally Posted by sambb View Post
    This sounds great. The website seems to be limited with where they'll ship to; and NZ isn't on the list.
    Feb 2015
    For a Polo GTI?
    Same question? For a Polo?
    Dec 2014
    coopers plains, QLD
    i see what i have done here.....
