From what I understand is the K03s and K04 use same size compressor wheel? K03s has slightly smaller turbine wheel/housing (not sure which one, if not both) than the K04...SO IM ASSUMING the K03/K04 turbo will be a different attachment on the turbine wheel housing assembly? Isn’t that what a k03/k04turbo is? Your original turbo with the different assembly?
