In the PCV vacuum line which goes from the crankcase T piece to the inlet mani, I run a proper 1 way valve in line with the PCV valve. That’s insurance to prevent the boost pressurising the crankcase as PCV valves fail all the time. Just use one of the n249 or sai ones that you probably have laying around. That’ll rule out boost pressurisation of the crankcase getting oil up past the oil control rings as a possible cause of the oil. Maybe plumb in a catch can too and see if there’s oil getting into the intake that way.
