Page 3 of 44 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 431
Thread: simon's learning what to do with the polo thread
  1. #21
    Oct 2017
    Wodonga, Vic
    thanks Gary - my mechanic mate has a couple of different styles of strut top in a drawer, one pair look like those from Suspension Concepts that can move in 4 directions. There is another set that just do camber... but I still reckon I can make one...
  2. #22
    nsw
    For Sam, the red FWD car at the workshop on Saturday has a standard front swaybar, compared to the all singing, all dancing rear
    Is that right! That rear bar arrangement got me inspired. Ive been thinking about aluminium solid bushing mine to the beam (grooved with a grease nipple), I'm doing some stronger rose jointed rear droplinks (adjustable on one side). I'll definitely be going to the hardest rear bar setting for the Faibairn Park Canberra hillclimb round in a couple of weeks now.
    Gary[/QUOTE]
  3. #23
    Oct 2017
    Wodonga, Vic
    Quote Originally Posted by sambb View Post
    Gary
    [/QUOTE]
    interesting - how can I get a picture of the rear bar setup on this car??
  4. #24
    Apr 2015
    Quote Originally Posted by me
    for sam, the red fwd car at the workshop on saturday has a standard front swaybar, compared to the all singing, all dancing rear
    is that right! That rear bar arrangement got me inspired. Ive been thinking about aluminium solid bushing mine to the beam (grooved with a grease nipple), i'm doing some stronger rose jointed rear droplinks (adjustable on one side). I'll definitely be going to the hardest rear bar setting for the faibairn park canberra hillclimb round in a couple of weeks now.
    As I mentioned it's chrome molly tube, gives the rate without the weight (of a solid bar). I'm working on a design for the front swaybar, same material, mostly for the weight saving. The driver adjustment is a bonus on the front, but it is very necessary on the rear.
    Being chrome molly with alloy bushes it doesn't need greasing. If you polished your spring steel swaybar, clean off the paint and give it a buff with 200 grit on the linisher, it would only need the occasional spray with RP7.
    Gary
  5. #25
    nsw
    ha ha That up to Gary. Its racing in IPRA this weekend so it might be classified.
  6. #26
    Apr 2015
    That rear swaybar set up probably cost $2.5K, with about half the cost of hardware and the other half design and engineering.
    Gary
  7. #27
    Apr 2015
    Like the military we have multiple levels of "classified", there's confidential (C), secret (S), top secret (TS) and sensitive compartmented information (SCI). That one is definitely SCI.
    The front one, when I finish it, will be level 5, which is so secret that it doesn't even have a name.
    Gary
  8. #28
    Oct 2017
    Wodonga, Vic
    Quote Originally Posted by Sydneykid View Post
    Gary
    understood sir, don't even acknowledge that there is anything to ask about
  9. #29
    Oct 2017
    Wodonga, Vic
    putting this here for reference purposes... "DTMWorks rear stiffener bar for Chev. Sonic"
  10. #30
    Oct 2017
    Wodonga, Vic
    As you probably already know Superpro make a caster adjustable rear lower control arm bush SPF3397K, on the Golf's we used to also make adjustable crush tubes that supplemented the offset in the bush itself and also gave some adjustment so we could finely match caster, side to side.
    Gary
    hmmm.. SPF3397K lists for Audi TT & Golf MK4 - I'm not sure of the equivalent for Polo but it ought to be SPF3273
    info for my reference
    old thread about bushes Replacing Dog Bone and Control Arm Bushes
    dogbone - SPF2907-70K
    LCA front bushes - SPF3311k
    LCA rear bushes - SPF3273k
    sway bar bushes - SPF2901-20K
    rear beam pivot bush - SPF2481K
    question for you clever fellas
    there's some other little thingy that goes somewhere on the rear beam that stiffens something - from what I saw it was about the size of a 20c piece and it'd take 2 minutes to make it out of a bit of nylon, but I don't remember what it was or what it did... ring any bells?
