Originally Posted by
sambb
so after finally getting the MCA fronts corrected so that I could fit them up, I moved onto the back MCA's. They were untouched in the accident and had just been waiting to go back in once the front was stiffened up to match.
This time I thought I'd check everything properly. After adding up the fully compressed heights of all the platforms, shims, helper springs etc and the working spring I calculated the fully spring bound length between bottom adjustment collar and the chassis. I then fitted up the dampers without the springs and jacked the beam to check that the damper length/bump stop position was correct. It turned out it wasn't. The springs would have been coil bound and the bump stop was only starting to be active. So I had to wind the base adjuster down to lengthen the damper body. This increases droop and pushes the top of the damper body closer to the bump stop. Once I got it so that the bump stop was fully compressed and the spring was a safe distance away from being coil bound I fit it all up.
Thats where the problems appear.
Basically to get the damper body length correct to prevent coil bind, you end up introducing so much droop that the main spring whilst still connected to the helper is not captive over the adjuster. Now I could spin up a cone shaped aluminium guide to fit into the end of that adjuster cup to get around this, but the other fundamental thing wrong is seen on the damper shaft. The cable tie on the shaft shows how much shaft is taken up in droop and how much is available for bump. After taking it out for a test drive the insufficient bump travel can be seen here:
the tell tale cable tie has been pushed to just below the bump stop. While it wasnt going to coil bind and throw me off the road it was only a smidgen off really hardening up in a nasty way. Once out on a circuit pulling much bigger cornering G's and then riding up an outside kerb, this would definitely be going well into the stop.
SSSSssooooo whats the solution. It seems that the keeper arrangement coupled with a low ride height really restricts travel. I could increase ride height to gain travel but then the springs would fall clean out at full droop, and I need it to operate at that ride height.
advice needed!!!
