Page 190 of 190 FirstFirst ... 90140180188189190
Results 1,891 to 1,896 of 1896
Thread: Sam's build thread
  1. #1891
    nsw
    And does anyone know if its ok to mount a battery actually in the cabin. I figure if you can put a battery in the boot of an un-fire walled hatch then there shouldn't be a reason why you cant put one under the passenger seat.
  2. #1892
    Apr 2018
    Bayside, VIC
    Chassis is the car's ground anyway, shouldn't be any different as long as it's secure as well as in an open(but protected) environment(not right under the seat). ?Maybe I'm wrong, but I don't see any trouble other than fatal harm if it suddenly explodes and the plastic shrapnel collects you with it. Or fire or whatever. Hence the Hood/Trunk locations tucked under more protective layers.
    Probably need a profession to explain as to why, can only assume
  3. #1893
    Apr 2015
    Quote Originally Posted by sambb View Post
    A low profile Odyssey style I assume? Who's ever going to know that it's there? To be sure I'd probably cover it with some 3 mm acrylic sheet, DIY the bends with a heat gun. For the Skyline I located the lithium battery in the console, makes for short run cables via the isolator switch next to the gear lever.
    Gary
  4. #1894
    nsw
    Yep it'd be a dry cell type. Main reason is to just get it right out of the engine bay but not to the boot where I need every bit of free real estate for when the car is packed up with rims/tools/gear for events and like you said a shorter accessible cable run that will be easy to break into with a cabin mounted isolator when the day comes to do that.
  5. #1895
    nsw
  6. #1896
    Jun 2011
    Sealed units are ok to mount in the car cabin. Any other type that may vent needs to be in enclosure that in turn vents outside.
