Results 1 to 10 of 14
Thread: Bzzzzzzzzz *tick*
    Essendon
    Bzzzzzzzzz *tick*
    What is causing this noise? It's not a problem, I'm just curious.
    If you get into your car and turn the accessories/auxillary on, you'll hear the noise. My first thought was the fuel pump. But yesterday, when I was cleaning my car, I had both doors open and the key was in the ignition but everything was off, I heard the same noise. WTF? Can't be the fuel pump if it's not on. Then again this morning, I walked out to my car, beeped open the door and as soon as I opened the door, I heard the noise again.
    Same noise, three varying times. It appears to be random. Any ideas what it could be?
    Jan 2007
    Quote Originally Posted by max_croft View Post
    easy...
    Flux Capacitor charging up...
    Mar 2008
    NSW
    i hear this noise as well everytime i unlock my door and open the door!
    You wearing those wind up jocks again?
    You know what the Judge said last time you wore them..........
    Nov 2006
    YOU know it's not on...but does IT know it's not on?
    2015 White German SUV
    2013 White German hatch
    2011 Silver French hot hatch
    2008 TR Golf GT TDI DSG
    Jan 2008
    Cremorne, Melbourne
    could be the air vents opening up.
    next time you start your car... put it in reverse and see if the same noise happens again (blocks fumes from coming in the car when reversing). then put back to neutral and listen again. if you hear the same noise it may be the air vents opening/closing up. i'm pretty sure they close up when you lock the car.
    apart from that it could be the start up process: AFAIK from when you open the door after unlocking the car goes through its own start-up with fuel pumps and other things. when you open the door something starts up, and then when you put the key in and turn to auxilliary, something else starts up. gets the little beastie all ready to go before even turning the ignition on. pretty cool IMO
    2010 Reflex Silver MK6 Golf GTI
    Sunroof - MDI - Superchip - 19" VMR V710 - Kuhmo Ecsta SPT KU31 - VW Racing Panel Filter
    As i know that is a fuel pump, it happens on my Golf MK4 and Polo GTI
    2013 4Motion "BLACK BEAR"
    http://blackbeartiguan.blogspot.hk//
    Mar 2007
    Yep ... fuel pump. There's a time lag involved. If you open the door immediately after getting back (from a drive) ... it doesn't do it. I don't how long the actual delay is, but after a certain time, opening the door activates the fuel pump to charge.
    Dave
    Apr 2008
    Canberra
    Quote Originally Posted by Golf Houso View Post
    easy...
    What is 88mph in km/h anyway?
    MARTY!
    MY08 Jetta TDI, DSG, Platinum Grey, Anthracite Leather, Foglights
    MY07 Polo TDI, Reflex Silver, GTI Wheels, GTI Suspension
    Jan 2007
    If a fuel pump makes a sound but no body is around to hear it, does it really make a sound?
