Results 11 to 20 of 29
Thread: Replacing gearbox oil
    Cheers, will order.
    Can anyone assist me in where the drain plug and filling point are? Can this be a funnel and hose job?
    The fill and drain will be 14 or 17mm hex or a M14 spline. The drain will face straight down and the fill faces forward IIRC. Funnel and pipe is the sensible way to do it.
    Undo the fill plug first, You don't want the fluid out of it and then find you can't put any back in!!
    Aug 2007
    Your level plug is at the front of the trans, 17mm internal hex. The drain is the same plug but underneath. Buy yourself a 17 hex socket. Buy yourself a Tom Thumb pump bottle which hold a litre of fluid, great little filler and no mess whatsoever. You can buy them in any good auto store and last resort you can get it at Autobarn. And make sure the gearbox is level, not the car that some may suggest, when the car is level the box is still a bit canted. The back of the car will be jacked a bit higher to achieve this. Really thats it, good idea is to go for a run and get the oil warm , itll drain quicker that way. Plugs get torqued up to 25NM.
    If you are still a bit unsure give me your email address
    Jmac
    Alba European
    Nov 2008
    Canberra
    Quote Originally Posted by Jmac View Post
    I aways use one of these - about 20 bucks from Autobarn and a total no mess solution.
    Jan 2009
    blankedy
    Checked in bunnings, they have a kit of them, but seems like overkill for just 1 x 17mm. Would anyone carry these individually (i.e., just sell the 17mm?)
    Nov 2008
    Canberra
    Just a reminder - the gearbox plugs are female, so you need a 17mm male hex key, not a regular 17mm socket. Dought if Bunnings have these, even in sets. Try Repco.
    Jan 2009
    blankedy
    Quote Originally Posted by Catfish View Post
    Yeah, I got that, otherwise I'd just use the socket set.
    Jan 2009
    blankedy
    Redline MTL went in about 100kms ago.
    Not too difficult to change after borrowing 17mm hex spanner and Tom Thumb bottle from mechanic.
    Took a little over 2 bottles.
    Gearbox feels better. It was not poor, but for <$100, its a little smother and quicker 1>2, 2>3, 3>2, 2>1. Think my gearchanges have become a little faster and I don't seem to be as aware of being cautious with the changes.
    Aug 2007
    It will get better still mate, give it around 300ks for the benefit, let the oil wick in to the bearings and syncros
    Jmac
    Alba European
    Oct 2009
    syd
    I was experiencing the 1st to 2nd gear crunch if you tried changing gears into 2nd without waiting, also happens even if dropping a gear down to 2nd.
    Got my mechanic to change the oil for me, and to my surprise, the gearbox only took 1.5 litres, car was on the hoist, I don't see where the other 0.5 litres is hiding. I know for a fact that its meant to take ~2.1L, not sure whats going on there, but I have half a bottle left.
    After I took the car out of there, I went into a few back streets, left the car in 2nd and drove slow, kept it in the gear for about 2 minutes, and ever since then, it shifts perfectly. No more crunching. I've already noticed its getting smoother when changing gears. The oil that came out of the gearbox was like water, probably the original oil that was first put into the car from new. The new oil that went in was a tad little thicker but maybe that's because it wasn't warm, anyways.. No more crunching, I'm happy about that, I can actually use 2nd gear now
    I also used Redline MTL, $40 a bottle from Bursons.
    Aug 2007
    Quote Originally Posted by Hilal View Post
    Good result mate
    Alba European
