Page 37 of 37 FirstFirst ... 27353637
Results 361 to 369 of 369
Thread: Polo Problems & Fix Register
  1. #361
    Mar 2016
    McCrae Victoria
    Quote Originally Posted by Slow_Polo View Post
    Mine has the exact same problem kaanage! The guy i bought it from said it has had the issue for ages and VW wanted in the range of $700 to fix it.
    Have a read of this page: VWVortex.com - MKIV door locks explained - why you're having problems!!!
    I haven't got around to checking mine out yet but hoping this simple fix will solve it.
    Luke
    What age vehicles does this apply too? I can no longer get into my rear (behind driver) passenger door, and the hatch back door is also a problem. I drive a Polo TDI 2008.
  2. #362
    Aug 2012
    Geelong, Victoria
    Quote Originally Posted by pgauke View Post
    This has gone all the way to VW Australia... Letter Below.
    "Dear Mr. Holland
    In May 2006 my wife purchased a VW Polo from Nepean Motor Group in Penrith, based upon recommendations from my father who at that stage owned and was very happy with VW Bora.
    At the 15000km service she advised the service department of a problem with the radio cutting out and erratically changing stations on its own. I was advised that the radio was reset and recoded this did not fix the issue.
    On the 27/02/2007 the car went back to Nepean Motor Group to get a new radio fitted to fix the original problem however this still did not correct the issue.
    On the 18/06/2007 the car went again back to Nepean Motor Group to have the radio looked at for the same problem however no fix was available.
    On the 20/07/2007 the car went in for its 30000km service with Nepean Motor Group and again the radio was reported faulty and the service department reported back:
    “CHECK/REPORT ON RADIO INOP AGAIN N/C
    CHECKED FOR RADIO INOP FOR THE SECOND TIME.
    CHECKED AND FOUND THAT RADIO WAS CUTTING OUT.
    CONTACTED VOLKSWAGON AND FOUND RADIO REQUIRED
    TO BE CODED. CARRIED OUT CODING AND FOUND DID
    NOT FIX PROBLEM. CONTACTED VOLKSWAGON AGAIN
    AND FOUND RADIO WILL REQUIRE REPLACING ORDERED
    NEW UNIT AND WILL ADVISE WHEN PARTS ARRIVE.”
    On the 31/10/2007 the car was taken back to Nepean Motor Group to have the radio “supposedly” replaced however after this the original fault still remains.
    On the 12/02/2008 the car went into Nepean Motor group for a scheduled service and once again the radio was reported as still having the same fault, however the service department said they could not fault the unit at this stage.
    On the 07/03/2009 the car went to Nepean Motor Group for its 45000km service where I again advised service that the fault still remained with the radio and was advised verbally that there was no fix available for this model of radio as this was the lower end unit. At this stage I was not happy with this answer but felt there was nothing more I could do.
    On the 29/10/2010 the Polo went in for its 60000km service back to Nepean Motor Group where I again raised the issue for the radio changing stations on its own. The service department tested and advised that yes the unit was still at fault and would take this up with VW Head Office. I was advised at this stage that car was no longer under warranty and a good will request would have to be raised given that the fault had been raised since the car was brand new and never rectified.
    I have now been advised that if I would like this fault fixed I would have to pay half the replacement cost of the unit. I feel this is totally outrageous as this has been acknowledged by VW service staff on a number of occasions as a genuine fault.
    As you can see by the attached service records we have made every attempt to have this issue rectified under warranty period without success. I would also like to note that this car has always gone back to the same VW dealer for each and every service.
    I would also like to point out that this is one of four VW vehicles in my family.
    My father owns a 2009 Golf
    My Mother owns a 2010 Caddy Maxi Life
    My brother now owns a 2010 Tiguan
    And all of the radios work fine.
    I consider the Polo with the continuing issues of the radio and the fact that this has never been rectified as a black mark on the VW family name. I’m even more disgusted that VW would expect me to have to pay out of my own pocket to have something repaired that was clearly a warranty issue that should have been fixed in the first instance.
    Given the ongoing issues with this radio that have never been rectified I feel VW has no other option but to do the right thing and if they cannot rectify the problem with this model radio than perhaps VW need to consider replacing it with another model of VW radio that is not faulty at no cost to myself.
    If I do not get a satisfactory result to this issue I feel I have no other choice but to refer this to the Office of Fair Trading. I would hope that VW will do the right thing in regard to this matter as it may reflect badly upon any future purchases of VW family vehicles."
    VW response you pay half $600 and we will look at it.
    Not happy Jane.
    Phil
    Just another example of VW Oz... can't trust the entire VWG.
    Owner and Operator of 2013 Polo GTI - Sunroof - Xenons - Reflex Silver
    APR Stage 2 Tune - HP Carbon Airbox - Jetex Stainless Cat Back Exhaust - APR I/C
    Plus a few other bits and pieces.
  3. #363
    Jun 2007
    Quote Originally Posted by steveyoshi View Post
    I don't get it, you've dragged up a post that was made 7 years ago by a member who made 5 posts about this subject on the day they joined and never posted again and from that you draw the conclusion that you can't trust VW?
    Have a look, you'll find many, many posts where VW have come to the party outside the warranty period.
    George
    06 Jetta 2.0TFSI Killed by a Lexus!
    09 Eos 2.0TSI DSG Loved this car but has now gone to a new home!!
    14 EOS 2.0 TSI has arrived!
  4. #364
    Aug 2012
    Geelong, Victoria
    Quote Originally Posted by VW Convert View Post
    George
    You don't need to get it... was just reading some old threads and some of the stuff happening all those years ago is still happening right now to others. Just because you believe there are many posts on where VW have done the decent thing... there is plenty of evidence of many people who have experienced the opposite.
    Not many people belong to online car forums either... as for 5 posts... and one day members... so their opinion is of less value than someone with more posts ?
    Anyway... don't bother answering... I don't care that much... it is my opinion and I'll stick by it.
  5. #365
    Jun 2007
    Yes, you are entitled to your opinion, not sure you're entitled to the overreaction to my expressing a different opinion.
  6. #366
    May 2016
    ACT
    Any advice regarding a engine noise?
    YouTube
  7. #367
    Nov 2021
    Brasil
    make - polo 9n3 sedan
    car usage - daily
    problem -
    comfort module unconfigured after changing the test instrument panel.
    description -
    comfort module stopped properly working, so i need to make vcds to solve the problem, i have already get cable v 12.12.3 to try to solve the problem, if some of you can talk to me about whatsapp i don't thank me here in brazil to solve free of charge.
    Whatsapp +55 75 99151-8293
  8. #368
    May 2020
    car: 2008 9n polo gti
    mods: revo "stage 1" tune
    car usage: daily, mostly short trips
    odometer: ~166kkm
    problem: electrical gremlins
    * same intermittent power steering failures other folks mentioned
    * same apparent "reboot" of the car while driving other folks mentioned — instrument cluster goes dark then lights up, (aftermarket) head unit goes dark then goes thru power up sequence
    * occasionally get ESC and ABS warning lights
    I normally have it looked after by a local shop close to home as I've found VW Sutherland and VW Village both love to waste my time and money on useless return trips, even when I say I don't need the car back that day (or week, even). Spending 2-3 hours and $100 on ubers/taxis getting the car to+from a shop when they haven't actually fixed anything and say "come back if it happens again" (another 2-3 hours and $100!) really pisses me off.
    If you know a good VW specialist in the Hurstville area I'm all ears
    edit: I should add that I've already spent way too much fixing this heap of junk and am extremely tempted to film it being crushed and enjoy the free space in the garage — but I'd rather get it sorted out and get at least some money for it
  9. #369
    If there's lights on the dash, even if they disappear, there's going to be a code stored.
    Power steering is probably the fuse on the battery. They get cracks in them all the time. Cheap to fix .
    Abs will have a stored fault for sure. Get the codes then we can help.
