Has anyone else had any issues with the boot on the polo refusing to open? You always find yourself at the shopping center trying to get shopping in the boot, unlock the car, and the boot refuses to budge! then sometimes its ok..
Found myself in this situation at least a dozen times now, girlfriends polo has the same exact issue..
Only way around it is to lock the car, wait a minute or two, then try again, until its willing, you will not get the boot open..
Anyone know of a solution to this
Cheers and Merry Christmas
2016 Golf R, APR Stage 1
2010 Polo GTI 9n3, 4 Program APR Tune, PD160, White line front and rear sway bar
I have mine set to open the doors with one press, gf's polo is a double press but doesn't seem to make a difference..
Spray some WD40 up into the locking mechanism. It might just be gummed up and not releasing
I just use the key when the handle is not working
Somehow the boot handle is using wire to control the lock not mechanical
Weird design
06 Polo TDi
Noticed the rear boot handle gets a lot of dirt behind it, hosed all the crap out and sprayed some wd40 into the lock mechanism, no jams so far
Hi flat6,was the abovementioned part (1t0962103) your problem,dit this fix the 'intermittent fault'.I am having the same issues with my 2013 polo Vivo GT 1.6.The boot lid wil have a 'no respond' issues every now and then.To climb into the back of a 2 door vivo is not that easy!!
