Update
Soooo been hella busy getting everything done and dusted.
White Polo, Stage 1 UGP all done! Fixed up PCV elbow, filled up petrol tank... yeah... my brother was close to empty and he put in another 3L in and what do you know xD running dry, only took 37 litres to fill her up(5L to get her to the petrol station for the remainder).
Grey Polo, managed to scout out a GTI at the wreckers, so got the sideskirt, hood, bumper bracket and last few bits needed to complete the build. Cleaned out the gutter under the wiper arms and wiped down as much as possible. Mounted the front end on, just got to reassemble the fog light lenses with some butyl. Car's pretty much ready for a roadworthy, last owner looked after it meticulously, absolute pity they spun out *clock spring wasn't put back properly and traction control was forever disabled *
And now my other white Polo hehe
Waiting on the rear brace, they should be all done getting powder coated by tomorrow, pick them up, install mine for tomorrow night and distribute the rest on Saturday. Have installed the infotainment system(works beautifully), sub is all wired in and have a plan for the old radio hole in my dash. Golf GTI steering wheel in, redone the wiring harness ready so when I get the control unit can make all the buttons work.
Fuel pump arrived finally after........ 75 days, yeah... Oh well, at least it's here.
Jobs for tomorrow are:
Trans fluid replacement
Clutch line replacement
Fuel pump to go in
Rear Brace to go in
Need to go find methanol somewhere :/ just thought of it :|
And then off to Gavin in the evening for its tune.
Going to be a very long day!
nice one. I had a squiz at the UGP post. 340Nm! I'll be watching to see if your rods stay intact!!
Gavin was quick at it! and yes THANK YOU!!!
So yeah, making a bit of fun power, had a few pulls tonight and I genuinely scared the **** out of myself. Gotta get used to it
Didn't get everything I wanted done on Friday, but the majority done!
Trans fluid, fuel pump got a wheel alignment done so it'll be good on the dyno and topped up as much as I could after the car sat for 3 weeks.
Still have the clutch line to do as well as replace a coolant hose(it's buggered ) which was my stuff up for instructing my brother to push it onto the radiator and m forgetting to clamp it...
Still waiting on the bracing should get the call early this week
Couldn't test out the watermeth on the dyno because of it which sucks but oh well..
Once that's all mounted, sub also gets mounted and then I've only got the steering wheel controls to finish once the controller arrives!
Then all the little things which I'll do over time and keep everyone updated on!
hehe Cheers
Simon!!
No worries, I seen the ad and yeah, LSD is totally worth it!!!
Jelwin
Just the stock one mate, think I've got a S3 one on at the moment. Because it doesn't have a bracket, it likes to move and squeak a bit as well as the pedal being a little softer than I personally prefer.
Hey Jan do you have a trace of the boost curve. I’m curious what boost level you are at for those numbers.
Also you ran EV14 550cc injectors yeah? How much duty cycle were they at?
Yeah a shame you couldn’t test the water meth on the dyno. Would’ve been good to see back to back comparisons.
Update
Car's absolutely beautiful. just <3
Car was having a bit of a piss on the dyno, sorry Gavin ahaha
Found out why yesterday. Thought the silicone cracked, but nope
Ignore my hands and work attire please xD
Replaced this clip and now it's not leaking anymore! Got a few bits and pieces for friends and to add to my spares pile
Got the rear chassis braces back today, already installed mine, watermeth tank and pump mounted, just have the subwoofer to do and then I'll take a photo of my setup. Already wrapped one up to send to WA tomorrow.
They look soooo good
Just waiting on the black ones to be ready
Also got my Watermeth solenoid today, have that too to install, should take 15mins max for mounting and soldering it in.
Still waiting for the steering wheel control module so I can finish that off.
Need to lower the screen by another 1.5cm, can be done and then build a shroud for it to cover its rear. It turned out not that bad.
After that the radio slot will become a phone holder with wireless charging for my new phone when it comes out in oct/november.
That's about all,
Enjoy your Tuesdays!
Sammm!
I do but it was for the first run Gavin did, not sure what logs he's got, ask him OR I can try run them tomorrow when I've got a moment. As for the duty cycle, same stuff. Unsure I asked to butt in and learn a bit but unfortunately at the shop can't be there forever.
I'm tempted to run again, with a fresh tank of fuel and watermeth and see how it goes. But also the idea of E85 lingers... Might do that next year. Upgrade injectors and rods and see how much further it can go.
Thanks gav. The boost doesn’t seem to fall away that much throughout the run for a K03 frame turbo. Looks good. How’s The F21 compare to your K300 overall?
