Update
So WMI AEM injector has a check valve, tried testing by blowing air through it and it wouldn't let anything through, so at high pressures it shouldn't be able to suck any more out of it than it has pumped through.
I sat again and tried thinking of a better way to mount the injector and I just don't have enough line to run it any other direction than from bottom facing up. I COULD also have done side facing the front but that situates it closer to the ambient inlet temperature sensor than down facing up.
Lined up the front end perfectly, had my younger brother to help out so it would be level and back in the correct place! Headlights back from my friend who done PPF on them, should keep them looking mint for a long time! All other small bits and bobs in the engine bay have been worked out and completed, there isn't much left to do there other than FLUIDS! Ordered everything I'm missing early last week, slight delay because one item was out of stock so full order was delayed. Not fussed for how much I'm paying for the whole lot.
Friend's Stage 3 Polo arrived at my driveway today and it was asking to fix its honeycomb center grill. Popped the bumper off and seeded it in without too much breaking force. Put it all back together and away he goes!
Started checking if I was able to put a map to run the car courtesy of Gavin! But... ran into a fun little issue of having a elcheapo VCDS cable Was a freebie so I didn't mind, but need to get myself a proper HEX+CAN cable for potentially a longer run. I have a little OBD11 dongle but it's eh. Worst waste of money for the Polo because there ain't much it can do for you automatically.
I also started working on putting in the coilovers. Got drivers side completely out but then I got tired and routed the WMI line to the boot, where I've got just. JUST enough to get it into the pump and have it situated in a nice position. That was a fun job!
Question. Tank can't sit 30 degrees offset, or can it? Might run out a tad quicker but gravity will still work, was planning on mounting it on the new rear strut bar when it arrives this following week. Then while it gets powdercoated, run a temp bracing setup for it before replacing.
Just last few things tomorrow, WMI wiring, coilovers, big brakes and finally to put the front bumper on and then to wait for all the last few small things to happen over the next few weeks.
