Weird Power steering noises??
Hi,
This is my first post.
I have a Polo Gti. All is well with it until today...
It was a scorching hot 40+ degrees day...
I was driving to the beach and back and my car developed a werid noise when turning... Like when you turn the wheel left or right, I could hear a noise from the front left side. Like a tick tick tick tick..as I turn the wheel. Sounds like the spring hitting something as I turn??? I lifted the car up and nothing seemed out of the ordinary...
It was hot under there... So I sprayed water from the hose on it and noise gone? Ill see in the morning if it does it when it all drys up..
Could it be a lubrication problem or heat? Something rubbing?
I cant find the power steering tank to check the oil?
I know exactly the sound you mean - I had exactly the same problem - it would come and go and would sometimes be more noticeable than others.
Take it to the dealer and they'll fix under warranty - it is a strut top problem (can't find the job card for the exact problem - moved house - chaos) but it€ is not unknown on the Polo and moreso the Golf so they should know what it is.
It's not a big problem and had no effect on the function of the car - I had it for a couple of months until the dealer finally ordered the part.
Hi,
Jacked up the car, twisted the spring round a little, creaking sound gone...
- You may not post replies
- You may not edit your posts
Forum Rules
