Page 1 of 7 123 ... LastLast
Results 1 to 10 of 62
Thread: JT's Polo Building Adventure!
JTop JT's Polo Building Adventure! 08-06-2020, 02:51 PM
sambb What turbo, injectors, pump... 10-06-2020, 03:11 PM
JTop Hey Sam! Still waiting on... 10-06-2020, 08:37 PM
sambb Manifold, MAF, TIP and... 10-06-2020, 10:32 PM
JTop Everything should be coming... 12-06-2020, 03:01 AM
Stein Hadn't ever heard of... 15-06-2020, 06:10 PM
sambb AET Turbos | 1.8T 20V Hybrid... 15-06-2020, 07:17 PM
Stein Not to derail the thread but... 15-06-2020, 08:55 PM
h100vw Littco and TIP delivered was... 15-06-2020, 10:43 PM
JTop 48539 From what I've seen,... 15-06-2020, 11:02 PM
h100vw Littco do a 280. I had one... 15-06-2020, 07:43 PM
sambb argh dumb ass. Sorry Stein, ... 15-06-2020, 10:54 PM
JTop Alrighty update Car got... 21-06-2020, 03:41 PM
sambb 134kw is 180hp. If you assume... 21-06-2020, 06:53 PM
sambb Keen to see how the K04... 21-06-2020, 06:55 PM
JTop Update Been quite busy... 03-07-2020, 01:57 AM
sambb Sounds like you've gone... 03-07-2020, 09:45 AM
sambb oh and the half moon for the... 03-07-2020, 11:24 AM
JTop Hey Sam! Put new gaskets... 03-07-2020, 02:48 PM
sambb The other option is to just... 03-07-2020, 05:10 PM
sambb So the AEM kit doesnt have a... 03-07-2020, 03:04 PM
JTop Update So WMI AEM injector... 05-07-2020, 02:09 AM
sambb Think there’s a genuine vcds... 05-07-2020, 04:31 PM
sambb Didn’t swear promise. That... 05-07-2020, 04:33 PM
sambb Yeah the check valve will... 05-07-2020, 04:53 PM
JTop Update Sam, this setup was... 07-07-2020, 12:26 AM
JTop Car's on the road! Did one... 08-07-2020, 01:34 AM
sambb good stuff. AEM are from the... 08-07-2020, 08:21 PM
sambb YouTube... 08-07-2020, 08:31 PM
Sydneykid I really don't understand why... 09-07-2020, 10:35 AM
sambb I’m hearing you Gary. I... 09-07-2020, 04:35 PM
JTop Update Another fellow 9n3... 09-07-2020, 10:16 PM
Sydneykid If you are going to move to... 10-07-2020, 09:26 AM
simon k hey Jan! - tell me more about... 10-07-2020, 06:18 PM
sambb Yeah ..... bolt or weld in? 10-07-2020, 06:50 PM
simon k likely bolted because it's... 10-07-2020, 09:23 PM
h100vw Downside to E85 currently is... 10-07-2020, 07:36 PM
sambb Jan if you end up running 98... 11-07-2020, 09:12 AM
JTop Update Day off today, hehe... 11-07-2020, 03:50 PM
simon k sorry for not getting back to... 24-07-2020, 03:12 PM
JTop Was a bit bored today on my... 13-07-2020, 01:28 AM
JTop Update Soooo been hella... 23-07-2020, 11:49 PM
jelwin What new clutch line did you... 25-07-2020, 04:39 PM
h100vw 48739 166kw and a pile of TQ. 25-07-2020, 06:20 PM
sambb nice one. I had a squiz at... 25-07-2020, 06:50 PM
JTop Gavin was quick at it! and... 25-07-2020, 10:06 PM
sambb Hey Jan do you have a trace... 26-07-2020, 12:04 PM
JTop Update Car's absolutely... 27-07-2020, 10:52 PM
h100vw 48867 here you go Sam 27-07-2020, 11:13 PM
sambb Thanks gav. The boost doesn’t... 28-07-2020, 11:50 AM
JTop Cheers Gavin :) Sam Those... 28-07-2020, 05:41 PM
sambb ha I was starting to think... 28-07-2020, 06:15 PM
h100vw Softer state of tune than... 28-07-2020, 07:37 PM
sambb How does that work Gav? Do... 29-07-2020, 03:04 PM
h100vw Yes Sam, intake temps play a... 29-07-2020, 07:51 PM
JTop Soo Been trying to finish... 31-07-2020, 11:59 PM
JTop It's been forever... ... 10-09-2020, 06:49 PM
JTop CIAOS XD 52455 It's been... 27-12-2020, 06:25 PM
JTop It has been a solid three... 26-02-2021, 03:28 PM
JTop Build's back to a halt. I've... 09-03-2021, 03:10 PM
simon k Sh*tballs.. that sucks, ×2 09-03-2021, 06:19 PM
sambb The League of Morons strike... 10-03-2021, 05:40 AM
    Apr 2018
    Bayside, VIC
    I decided to move from my previous thread and make a new one because it's become a build list. Left that open incase anyone does require ideas/help with FMIC and suspension although there are many good points scattered all over the 9n3 forum.
    Here is link to the previous thread if you're joining just now:
    FMIC & Suspension Upgrade Suggestions/Ideas
    The very long and overdue build update!
    Car is back in the garage only because of the small stupid sunroof overflows and my neighbors tree... It'll stay there anyway for the next month, will go out for a dyno day on the 20th and after that the last few stage 3 mods will go in!
    What has happened:
    Pretty much everything from my last post!
    Done all the exterior LED lighting, I can see at night now ahaha. Got a chinese auto light switch, which I'm fairly happy with, but it's like anything that comes out of china, EH o.k. ... Updated my AC dash dials to the chrome option, found 2 more sets.
    JT's Polo Building Adventure!-mvimg_20200523_000229-jpg
    Heated seating! Loom arrived 2 months later... Took a day and a half but got it all done. Hardest part was splitting the fusebox open to get the loom and to piggyback another cable to have the 15Amp fuse in slot #24. Rest was fairly straight forward, 1x to the light dial, 2x cables into the control module, 2x to controllers, 2x to the seats and the ground to the airbag grounding point which after more consideration can be a bad idea. All soldered and done properly comparing to the factory manual!
    Picked up Vogtland coilovers, probably best bang to buck for the polo right now from the UK. Whole ordeal this ended up being a good option. Comparing them to the KW Inox V1's, they're super similar but some dimensions and spring wounds look different.
    Finished the rear big brake upgrade with Audi TT mk1 carriers and caliper. I got a set of bora carriers (as I've heard still unsure if they're right) because I'm not happy with the creation motorsport spacers. Need to pull a wheel off and test if they'll be more suitable than the TT ones, then respray them red to match the caliper and throw them in!
    100%, slamming the brakes now, rear end wants to pull itself out from under the car, would recommend
    Have received braided lines so those have to go in too!
    Got a paint correction and it was looking great and then I took the car offroading
    JT's Polo Building Adventure!-received_576463696316750-jpg
    Other day have finished putting in the R8 coilpacks, bought the billets from the UK, $90 can't go wrong. Threw those in and also got a golf loom case to tidy it up more. N249 won't leave with this turbo, sure the SAI delete yes because racecar, but as it has always been installed and if German engineers put it there, not going to take it out! Maybe for the new turbo, but again I don't want to kill that either.
    What's left to do:
    Tomorrow, and I pray tomorrow that, turbo, injectors, water meth (because was a good deal on a full kit), all strut bracing and also front brakes get sent and arrive sometime this week so I can sit and do all the front end modifications.
    After they arrive I'll wait after dyno day before I start the final transformation.
    Sadly still waiting on my fuel pump even though I've waited more than 20 business days... Should arrive this week too.
    Have some fresh carpets coming from the UK close to the end of the month.
    Catch can install will be done too after the stage 3 stuff. Got all the right bits to do it.
    Another simple service, I didn't do the trans oil before because I was lazy, just checked the level and it looked good.
    Only few things that I think I'll do but over time.
    LSD! Quaife most likely, I have a spare box with a blown diff, so will make sure it can be built before I buy it.
    Bluemotion front lip, and get the side skirt and rear valance sprayed. I really want the cup edition rear spoiler! again it's one of those things, to find and get will be a pain, but well worth it!
    LED rear upgrade, with the VW infinity mirror badge, some guys done it in the UK, looks pretty cool.
    That's about it. Hope this wasn't a stupid long read, but I'm covering everything done/planned to the car, so it'll always be an extensive list.
    Peace, Love and Positivity during these times!
    JT's Polo Building Adventure!-mvimg_20200524_154543-jpgJT's Polo Building Adventure!-mvimg_20200524_154520-jpg
    nsw
    What turbo, injectors, pump etc are you planning on running mate?
    Apr 2018
    Bayside, VIC
    Hey Sam!
    Still waiting on them looks like next week.
    Frankenturbo K04 hybrid (typical)
    Bosch 550cc injectors (typical)
    Deatschworks DW65C pump which looks like it'll never arrive from sparesbox, most unreliable Australian retailer. Dealt with them 3 times prior and stuff always arrived a week or two late even before everything went down. I ordered this start of May...
    As soon as my exam is finished on Monday, I'm pretty much digging into the car finishing front suspension and BBK and throwing in the braided lines. Should take a day or two
    nsw
    Manifold, MAF, TIP and exhaust manifold from frankenturbo too as a kit, or are you cobbling together parts that you've sourced yourself?
    Apr 2018
    Bayside, VIC
    Everything should be coming as the kit, but again, I've been kept in the dark about all the details even though I've asked multiple times :|
    BAM intake manifold, doubt will change this. I've got the welly setup, holding strong 20psi right now. Might beef it up from 2" to 2.5" and get a thicker intercooler to comfort the K04, but again, unsure about it right this moment.
    Completely unsure if the exhaust manifold will come with the turbo. I want to port the exhaust ports and manifold, but it's one of those things that'll have to come later because I don't want to risk rushing and stuffing it up right now. When I'm done with uni and have a spare engine to build with forged internals, then sure, will get it done!
    MAF, 3" also coming in the package hopefully, otherwise I'll go grab the housing from an Audi at the wreckers
    TIP, again should be coming because I've asked for it and when I was placing my order at creation motorsport earlier last month, was comforted that it'll come with the turbo so I wouldn't have to worry about it :/
    Everything is meant to be sent from this Saturday (Monday processed from Sydney), so hopefully it arrives by the end of next week. It's been 4 months that I've waited for these bits to be taken off this car and get sent to me... Has slightly gotten frustrating but I'm patient
    Mar 2019
    Auchenflower, Queensland
    Hadn't ever heard of FrankenTurbo, very interested to see how all this turns out. Was looking at getting a BBT K300 but if the FrankenTurbo option is only a little bit more for a whole kit it sounds like a fantastic option.
    nsw
    AET Turbos | 1.8T 20V Hybrid K03 Turbo
    can check out these guys too. I may be wrong but I think despite BBT having a BBT280 on their site, they don't actually do it anymore. AET was sort of formed out of BBT and they do the smaller K03 hybrids for 1.8T's. Apparently a ported K03 exhaust mani can flow very well compared to a factory K04 one so there is that to consider too. I never researched the K04 hybrids really so cant help you there.
    If you ever go down the K03 hybrid route let me know as I have one spare that you could get ported ready for a K280 or 300 conversion.
    Mar 2019
    Quote Originally Posted by sambb View Post
    Not to derail the thread but if the AET is rated for between 260 and 280HP what would you say are the advantages over the cheaper BBT K300?
    Littco do a 280. I had one make 177kw are at UGP. Stick manifold, not ported. With Littco TIP, alloy MAF, Airtec twin pass and 550cc
    That's cheap, might as well the same price as the K300 was in 2019. I'd imagine its quite a bit better than the OEM units but do you know how that turbo is doing now?
    Littco and TIP delivered was $1700. Dont need to fit Rods which saves a pile of money.
    Not a cheap upgrade but then....... I have had 3 different hybrids on mine in its time.
    The main advantage of the AET over the K300 is the chances of actually getting one.
    Apr 2018
    Bayside, VIC
    Quote Originally Posted by Stein View Post
    JT's Polo Building Adventure!-turbo-jpg
    From what I've seen, the only thing different is the charge pipe muffler? (not sure if that is the correct term) and housing difference? Specs are so hard to find nowadays. The one Sam posted doesn't have a dimension specification, the BBT K300 has 51mm from what I read on this website
    BBT K300
    Littco do a 280. I had one make 177kw are(atw) at UGP. Stock manifold, not ported. With Littco TIP, alloy MAF, Airtec twin pass and 550cc
    I've touched his TIP a few times ahahaha
    Done the gentleman's lowering springs and had advised for uh, upgrading those dead front stock shocks. What's good to have power and then the car can't go around corners. These cars are to go left right, ciaos.
    My 2nd gear is this car's 3rd gear and it just keeps on going and then explodes, crackles and damages all hearing. Everything I wish to not do, unless I genuinely plant my foot.
    I looked at the Littco one, but at the time when I decided on the Frankenturbo, it was out of stock and delayed so
    Can't compare the price difference though
    So Yeah, that's the turbo coming this week, got 60kg of stuff sent to me TODAY and I don't think that was everything.
    I've got a big Aluminium/silicone combo TIP happening with the CreationMotorsport 3" MAF housing
    No Exhaust manifold is being sent so...
    Yeah I keep considering this, but I've got to ask the UK boys how they do them, or Gavin??
    Will send you a PM later, need to sort the tune out Da he ve he he
    Everything will be anyway delayed because Sparesbox is holding my money and not confirming my order after a whole month and a half... WTF, who pauses someone's order... That's pretty much what they told me... They deleted all my comments off their insta, and if I did on FB would be the same so I can't be bothered... 1/5 on google as soon as I get it, whether I get it or my money...
    I'm starting tomorrow to do a few bits, Wednesday should be back in the garage to get the final suspension upgrades and then
    Car's going on the Dyno this Saturday!
    See what it currently makes, then it'll go back into the garage and dig into it, get it done and be finished lol
    Nothing more on the performance side, just keep everything maintained and yeah, enjoy the car finally.
    Last edited by JTop; 15-06-2020 at 11:07 PM. Reason: and i ooped lol, everyone posted whilst I was writing this up
