Threaded View
sambb disabling ESP 01-09-2015,
05:01 PM
seangti I turn off TC when doing... 01-09-2015,
09:04 PM
sambb Sean, is that definitely... 02-09-2015,
11:17 AM
sambb tell me more. I've read... 02-09-2015,
08:57 PM
sambb well I went for a very... 14-10-2015,
04:03 PM
sambb well went for a drive to... 17-10-2015,
03:46 PM
Martin I was modifying the brake... 25-10-2015,
11:08 PM
sambb I found this quote in a... 15-11-2015,
01:28 PM
Blue9N3 I pulled the abs fuse some... 19-05-2016,
07:15 PM
sambb I hope you give it a go... 20-05-2016,
10:23 AM
kaanage Since the PoD is so... 20-05-2016,
05:43 PM
sakisvag Not the case if you have... 22-05-2016,
09:54 PM
sambb bit of an update to this... 10-08-2016,
11:49 AM
sakisvag delete 12-09-2016,
03:19 AM
sakisvag delete 17-09-2016,
05:42 AM
sakisvag delete 18-09-2016,
03:14 AM
sakisvag delete 25-09-2016,
09:07 AM
seangti You probably need to get a... 03-01-2017,
09:20 AM
disabling ESP
Can anyone tell me the effect of pulling the ABS fuse with a view to disabling ESP/ABS/TC etc. I assume it will bring up a code but will it be a 'limp mode' type of situation or can you drive without issue?
On some other forums apparently when its done to the SEAT's, the only i'll effect is slightly too much rear bias. Anyone have any experience with doing this? - not just the code side of things but driving it hard that way
- You may not post replies
- You may not edit your posts
Forum Rules
