Results 1 to 10 of 14
Thread: Swaybar Updates
    May 2007
    Burleigh Heads, Qld
    Swaybar Updates
    Have read through some of the older posts about swaybar upgrades. Some people think only the rear is required, some front and rear.
    Given there was a group buy, there should be quite a few out there now. I'd be interested to hear feedback from those who have them (front and/or rear).
    Mine is road use only - not that concerned about ride quality issues - I'm looking for more of a gocart feel without going to the expense of new shocks/springs.
    P.S - now just over 3,000kms in just under 3 weeks
    Mar 2007
    Thumbs up
    Pete,
    I just put the rear one one a few weeks ago ... love the change. It's currently set at the middle position and, chasing Spec83 up Nebo ... um ... let me rephrase ... having a spirited drive up Mt Nebo ... tail end stuck like glue whereas Spec83's Pogo was getting some serious rear squirm & jiggle on. Loads of fun highly recommend at least putting the rear on.
    Dave
    Mar 2006
    South Hobart Tasmania
    My therory is a car should be balanced.
    The rear of the polo has no sway bar at all to start with.
    By putting one on it helps the turn in and body roll to a point. Its not just a rear sway bar but the adjustable version is an uprate one.
    To counter this a thicker by 2mm front gives you the abilty to tighten the hole body not just the rear keeping the car at a balance and giving the driver a more positive feed back.
    A front may also be needed if dropping the car any more than 40mm due to the steering arms hitting the standered sway bar like the mk4 Golf suffers.
    I find my polo is great at the mo i can push the car into a corner with easy and on the exit its really easy to feel all the time what the car is doing.
    My polo is entered this weekend in a hill climb last year everything standered apart from an Apr tune it did a 49.18
    This year all suspension wise i have done is front and rear sway bars, will be good to see if there has been an improvement with the same power.
    Mar 2007
    Good luck at the hill climb, Mate. Keep us posted with your times.
    Cheers,
    Dave
    Nov 2006
    Quote Originally Posted by PeterHBne View Post
    I think you'll find the adjustable Whiteline will give you just what you're after
    Mar 2007
    Newcastle, New south wales
    swaybar updates
    I have whiteline front and rear adjustable swaybars,
    As forementioned the rear sway bar makes quite a positive difference. Helps to keep it flatter through corners.
    I then added front sway bar when i got the car lowered. So i cant really tell you how much of a difference the front bar made because i got Eibach pro kit in at the same time. But overall now, its loads more fun to drive and ride quality has not suffered too much.
    May 2007
    Burleigh Heads, Qld
    Thanks guys - as I understand it, the whiteline front is the same thickness as standard, the only diff being the whiteline is adjustable?
    Has anyone with standard suspension, changed the front with the whiteline? Did it make any difference?
    Mar 2006
    The front one is 2mmm thicker
    Jul 2007
    Auckland, NZ
    i would really like to get Whiteline rear sway bar adjustable, but I am from new Zealand. Do you know what is the best way to bring one to NZ??
    I am keen on rear at this stage, as front I heard is a bit more difficult to install.
    any hint or help would be highly appreciated...
    and how much do they go for these days without group buy? i missed it as i just got the car at the end of July...
    thanks guys!
    Sep 2006
    Brisvegas
    im pretty sure i can still get them off the guy for the same price. pm me details on address and ill find out prices for you.
    For Sale 2006 VW Polo GTI
    Have a Look
    CUSTOM CODE
    Phase 2
