Results 1 to 6 of 6
Thread: a few K03 turbo flange questions
    nsw
    I'm in the process of getting some bits together for an upcoming dump pipe and have a few questions:
    1. I've seen some fuzzy pictures of the k03 turbo outlet that measure it at 3/1/2 inches. Can anyone confirm this?
    2. Does anyone know the I.D of the stock exhaust flange and if it matches the profile of the turbo outlet housing?
    3. If you have it all port matched at the turbo outlet, does the OEM gasket line up spot on or do you need to go to an aftermarket gasket?
    4. anyone have any spare flanges lying around?
    thanks
    Jan 2014
    Clontarf, Queensland
    Quote Originally Posted by sambb View Post
    thanks
    I think Gav has some flanges made up from memory.
    Mods >1
    The guy that made my downpipe had a few flanges cut. Referenced off a new gasket.
    I have a K03s in the cupboard and the top end of a std downpipe here. If you confirm what dimensions you want Sam I'll break out the verniers.
    nsw
    That'd be great thanks Gav. I was after the I.D of the turbo's outlet flange and also the I.D of the standard dump pipe flange.
    thanks
    sam
    thanks
    sam
    2 minutes
    EDIT
    Both are 3.5 inch/88-90mm give or take
    nsw
    legend! thanks
