Originally Posted by
spraycanmansam
Whats the relation?
I've started thinking about this with the onset of summer.. the poor little stock SMIC is feeling the summer heat.
I'm aware that the ECU can pull timing to stop detonation. Hotter intake charge temps would increase the chance of detonation, so the ECU would pull more timing on hotter days. Less timing = less power even with the same boost. So from what I gather, it's the combination of increased boost with more timing that equals better power.
Fitting a larger intercooler will reduce the intake charge temps considerably. I guess what I've been wondering is if I will see a considerable power gain by fitting the SEAT cooler? I'm running the stock SMIC at the moment and the intake temps are horrendous... if I'm correct, it has to be pulling a fair amount of timing. Fitting the SEAT cooler should lower the temps and give me my timing back.. more timing with the same boost should equal more power right?
Additionally, is a larger intercooler enough? I have been taking a hard look at water+meth injection to further cool the charge.
