Results 1 to 9 of 9
Thread: Mobile phone holder. How did you mount yours?
    Jan 2008
    Since I been working this new job and spending more time in traffic I been looking at mobile phone holder for the car. There are thousands of mobile phone holders that stick to the window with a suction cup but im looking for something that will mount somewhere lower and more discreet. I dont want the boys in blue to see if im checking my messages while sitting in traffic or at the lights.
    There are the one that sit plugged into the cigarette lighter which is not exactly ideal considering the lighter plug sits under the flip up cover. I dont want to drill holes in the dash, superglue leaves a mess if it ever has to be removed and two sided tape does not hold well if you travel on bumpy roads.
    I have found this as possible option:
    Amazon.com: Brodit ProClip VW Volkswagen Polo 02-09 #853027: Electronics
    Or maybe something like this (not sure if they make these for the polo:
    Amazon.com: Panavise Custom InDash Mount for VW Jetta '05.5-06,GT '06,Rabbit '06: Electronics
    Would like to hear your ideas. Pics are even better!
    Oct 2010
    Melbourne, VIC
    I have a cheap POS vent mount holder that I bought from Big W and have stuck in the drivers side vent. It's OK except that I need a piece of elastic around it to stop the phone falling out occasionally.
    Resident grumpy old fart
    Dec 2006
    Kilsyth, VIC
    I used these guys for my mount:
    Mobile Phone & GPS Car Holders
    And the Polo Mounts:
    http://www.holdmyphone.com.au/select...2_09#dashmount
    They do vent mounts too and the best part is none of them require drilling so can be removed if you ever need to. The other bonus is if you get a new phone you keep the base plate and just replace the phone part with the appropriate part.
    They are a little on the expensive side, but work very well.
    May 2013
    Orange NSW
    RE: Mobile phone holder. How did you mount yours?
    I bought one that fits in the cup holder and has a gooseneck for the phone. It tightens in the holder so it doesn't move.
    Sent from my RM-821_apac_australia_new_zealand_304 using Board Express
    08 MY09 R32, DBP, DSG, GIAC, R8V10 reps, KW V3, RNS510/VIM/BT/MDI, region free DVD, switched Haldex, s2t paddles,HPA dogbone rubber,Mk7 climatronics, FIS+, Adams/RDA discs & Hawk pads, Garage button, GruppeM. Front fogs, Milltek. CF Chin spoiler.Strut support. LEDs Alloy front suspension bits.....
    http://photobucket.com/gregsr32
    Eltham, Victoria
    I found a phone holder that came with an ancient LG flip phone when I was in high school. It now slots perfectly in the drivers side vent. I'll try and get a pic over the w/e
    May 2012
    Perth, WA
    How about this?
    06 Polo TDi
    Apr 2013
    Sticky 2" velcro, can't beat it. I've been using velcro on all of my cars for the past 10 years. Get the 2" wide stuff from Bunnings or somewhere similar, stick a 3" strip of it (the rough side) somewhere on you dashboard and stick the soft side to the back of your phone...
    Cheap, simple and it works!
    AT
    Oct 2010
    Melbourne, VIC
    Every state's road authority has a rule to this effect (the wording may even be identical - this is taken from NSW)
    The phone must be in a commercially designed cradle and affixed to the vehicle in accordance with the manufacturer’s instructions. It is not necessary to have the cradle professionally installed.
    It is not permissible to affix a mobile phone to a dashboard with velcro, or by other ad hoc measures.
    I have the Clicon/Brodit mount in my Polo. Had it for 3 yrs with no issues.
    HoldMyPhone mountings are the same as Clicon/Brodit. Cheaper to get it from UK
