Page 1 of 38 12311 ... LastLast
Results 1 to 10 of 378
Thread: Red Devil mkII - The Journey Continues
    Jan 2009
    **** FOR SALE **** $12K
    Hi,
    As Anthony had decided to part with the Red Devil, I saw it an opportunity to buy the car for regular track work.
    I'd been teetering with the idea of buying it over a few months when he first announced selling. I gave in to the idea after a track day where an RX7 and GTR punched the wall. Plus I have plans on lots of track time this year, so rather than dump money into the current silver one, thought it's money better spent sitting in an already exceptionally well built car. I'd initially considered it as a daily, but rather than soften it up and detune to make it more streetable for my requirements, I thought it'd be a waste of the hard work that's gone in to it, so will keep flying the track oriented theme.
    On the immediate horizon is getting baseline performance figures; 0-100kph, rolling speed intervals, lap times at he local tracks and quarter mile. I'll share that once compiled.
    RE mods, before track time next weekend I will soften up the front sway bar to dial out some understeer / promote more movement in the rear. Though will be replacing the coilovers in the next month or two, likely to H&R or KW's. I also an expect an LSD will be needed, have done some research and likely to be wavetrac, will get some track time in it first before committing.
    Build on the car when I took delivery.
    Enough waffling, I'm now sporting two Polo GTI's.
    Current Spec - Nov 2017
    VAGAutowerks custom tune
    3” cold air feed ducting
    Modshack VTDA with custom cold air 3” ducting inlet with K&N pod filter
    Custom alloy 3" MAF housing
    Custom 3" turbo inlet pipe
    Removed June 2015 Billet Turbo Ko3s Hybrid turbo with ceramic ball bearing conversion with Forge adjustable spring turbo actuator - yellow spring
    FTG K04-001 with upsized wheels (62.3mm compressor, 46.4mm turbine wheels) with Forge adjustable spring turbo actuator. refer page 26+ for info and pics
    Forge Motorsport 007P closed loop diverter valve with yellow spring rated 15-23psi
    SEAT Sport intercooler - dual pass core
    Custom pipe work - 2" hotside, 2.5" coldside to TB
    Removed November 2014 ATP turbo hiflow exhaust manifold HPC coated - as it cracked. Running standard Manifold.
    Custom stainless steel 3” dump pipe with 4" expansion chamber & Magnaflow 100 CEL catalytic converter
    Custom 3" stainless steel catback exhaust with Magnaflow resonator & 6" round muffler with 42DD 4" outlet
    Phenolic intake manifold gasket
    ECS lightweight crank pulley
    42 Draft Design Ultimate catch can with Morosso exhaust valve and PCV delete - currently removed
    SAI Pump, N249 & N112 delete
    Wahler 71c thermostat
    Genesis II 500cc injectors
    Bosch 3 bar FPR
    APR high performance in tank fuel pump
    Verdict Motorsport O2J aluminium shift bracket bushings
    42 Draft Design aluminium shift cable bushings
    Deka lightweight ETX14 battery 12lbs 5.4kg
    Braille aluminum battery mount
    NKG BKR7EKT spark plugs
    Superpro sports dog bone bush
    Vibra-Technics Gearbox mount
    Vibra-Technics Engine mount
    Audi A3 custom drive shaft
    Sachs 228mm duty clutch plate
    Sachs clutch pressure plate
    ECS 14lbs light weight flywheel
    Wavetrac LSD and rebuilt gearbox April 2016
    Wiechers steel front strut brace
    Ultra Racing front lower control arm brace
    Ultra Racing rear lower brace
    Ultra Racing middle lower brace
    Whiteline adjustable front sway bar 22mm
    Whiteline adjustable rear sway bar 20mm
    Whiteline rear shim kit +3mm toe in reduction
    H&R Coilovers (20-50mm lower) with Kmac adjustable camber and castor tops
    Superpro anti-lift poly rear control arm bushes
    Brembo 4 pot front brake calipers
    QFM A1RM front
    DBA 4000 312mm front slotted rotors
    Audi TT rear brake calipers with VW Bora V5 All-wheel drive brake calipers
    Lucas/TRW rear brake pads
    RDA 256x20mm ventilated rear slotted rotors
    HEL braided brake lines
    Track: Enkei RPF1 17x8, 35ET, 15.5 lbs 7kg
    225/45/17 Yoko AO50 Soft
    Daily: Audi TT 17"
    Federal RSRR215/40R17
    MK5 Golf alloy steering wheel inserts
    SWG air vent pod
    Prosport Evo electronic boost gauge
    Prosport Evo electronic EGT gauge
    Prosport Evo electronic air fuel gauge
    Ford Focus RS bonnet vents
    APR Performance GTC-200 48" SCCA Spec. carbon fiber rear wing
    Rear bumper valance delete with JMF alloy bumper diffusers
    Sharan antenna
    Badgless upper honeycomb grille
    Fog lamp delete
    Side skirt delete
    Lap times (Official - natsoft):
    Lakeside, QLD: 1:03.18 (on old turbo at 22psi, RE55s tyres)
    - 1:03.2 (FTG turbo at 16 psi, V70 tyres)
    - 1:02.99 (FTG turbo at 16 psi, V70 tyres, Wavetrac LSD)
    - 1:02.86 (FTG turbo at 16 psi, Federal RSRR tyres, Wavetrac LSD)
    Queensland Raceway
    Sprint configuration - 1:00.596 29/09/18
    Clubman configuration - 1:04.372 29/09/18
    National circuit - 1:28.113 29/09/18
    Sportsman Circuit - 1:01.913 29/09/18
    19 Sept 2020
    Sprint configuration - 1:00.274
    Clubman configuration - 1:04.082
    National circuit - 1:27.58
    Sportsman Circuit - 1:01.677
    Wakefield, NSW: 1:12.4 (on old turbo, RE55s tyres)
    Daily: 2010 VW Jetta Highline
    May 2012
    Looking forward to seeing this car on the track Sean.
    Congrats on the purchase and I'm sure the car will be something pretty special when your finished with it
    Feb 2007
    Brisvegas
    So much win coming soon Nice pics too!
    Jan 2011
    Brisbane - QLD
    MINI Cooper S Clubman - FWD
    Jun 2009
    Can't wait to see this thing on Saturday's Happy Laps.
    Dec 2006
    Cant wait to see qtr mile time sean. I hope you meam wbank and not just gtech??
    Sent from my GT-I9305 using Tapatalk
    Quote Originally Posted by seangti View Post
    The price of the car rarely indicates driver ability/lap time.
    Jan 2009
    Quote Originally Posted by jasn78 View Post
    Yup, willowbank mate, can't achieve bragging rights without a time slip
    Though never done drags, so if I suck at it you may never know I'd tried, lol. Nah, I'll share my failures.
    Dec 2006
    Im sure u will be fine remember low psi front high psi rear and slip ckutch against handbrake to control tyre spin.
    Also dont worry about the lights go anytime after green
    Dec 2006
    Or just use me as the driver pmsl
