Results 1 to 10 of 20
Thread: Can a KO4 Polo GTi driver review?
    Jun 2008
    Perth
    Hi there any Polo Gti driver had the KO4 Turbo upgrade?
    If so is there any chance of a review? Opinions? For and againsts?
    Thanks heaps
    Mar 2007
    Eddy? Did you buy Guy's KO4?
    I'm guessing not ... otherwise your's would have been putting out these figures at the Polo Dyno date.
    http://au.youtube.com/watch?v=ckUWiZ...eature=related
    Dave
    Nov 2007
    Not too many K04 Polo's around. I have driven the APR Polo when it had the K04 on. It was awesome. Heaps of smooth power. I think the 151kw atw from the video clip is a bit on the low side as it felt much stronger.
    There did seem to be a problem with the turbo/manifold bolts though. Not sure if it ever got resolved.
    I still plan on fitting a K04 to my car at some point. 6-15 months away.
    Sep 2006
    Tweed Heads
    Quote Originally Posted by DaveMack View Post
    Dave
    Hoyhoy.
    Na me didn't Dave.
    Hooroo.
    Feb 2007
    Brisvegas
    If your going a K04 you may as well go all out and move to a T25 or T28 IMHO... You have to get new manifold / dump pipe / exhaust anyway, plus you have a much larger choice of turbo combinations to suit the way you want to power delivered...
    Either of the above options will cost $5,000 +
    '06 Polo GTi - Candy White / Custom Leather / Looking for Dish!!!
    Dec 2006
    spec83 while i agree with you on the preffered choice a k04 kit from apr just as an example is only just over 2k not 5gs
    Quote Originally Posted by seangti View Post
    The price of the car rarely indicates driver ability/lap time.
    Dec 2006
    Gold Coast
    I want a gt3071r powered polo.
    Make software dammit.
    Ill do the rest of the custom work.
    Nov 2007
    If you already have the exhaust, you don't need anything else but the K04 as it simply bolts on and all fittings and feeds work perfectly. So fitting it will only cost you about $2K including 4bar FPR and software.
    If you go anything else there are manifolds, exhaust mods, oil feed mods, software, etc to be done and $5K is probably optimistic.
    Difference is K04 is worth 150+kw atw whereas a bigger yet turbo kit will be 200+kw atw......
    Considering the traction problems of the Polos do you really want 200+kw atw? ...... Realistic answer is no ..... power hungry answer is yes ....
    K04 is as far as my Polo will go. I'll buy a better car if I need more power than that.
    Jun 2007
    The KO4 kit is usually the KO4 001 (older, smaller KO4 version) which is why it bolts on relatively easy. You'd need to upgrade the intake, install a FMIC, definately brakes ...and if you don't upgrade the clutch, you can count the days before your stock one collapses. The KO4 will flow better and hold power better in higher rpms, but don't expect a massive power increase over the KO3S. ..although you can expect more lag.
    Mar 2007
    Gold Coast
    What's that little white car in your sig Johan? How did the Mk1 go getting power down? Did you have an LSD?
