Results 1 to 10 of 11
Thread: Trouble starting
    May 2007
    Jimboomba. QLD
    Trouble starting
    Hi, I have a 2010 90TSI manual. It has trouble starting.
    Cranks over, won't fire.
    Pull the ECM fuse (13 from memory), replace with the same fuse, fires first time.
    Any clues?
    2010 90TSI Manual / Comfort Pack / United Grey
    RICE - Leave the useless wings to the Penguins...
    Pacific Paradise QLD
    Battery or fuel pump
    Have you got a scan tool you can use to at the very least see if any error codes have been logged?
    2017 Ford Fiesta ST
    May 2007
    Jimboomba. QLD
    Scanned and the only error was "Lost communication with the ECM"
    Update. Had the Fuse panel under the hood replaced as it was believe that the "pull the fuse and it starts" was an issue with the fuse panel.
    Sadly, we are back to the same issue.
    Car will crank but not start. Pull the ECM fuse and immediately replace. Car starts first crank.
    The car will continue to start multiple times through the day without issue.
    Park the car over the weekend, try to start Monday morning.....cranks but not start. Pull the ECM fuse and replace, starts first go.
    Very weird.
    May 2007
    Jimboomba. QLD
    I believe it has one, how would I check if the relay is stuffed?
    Replace it, or at least take the cover off and send me a picture. Might have a dry solder joint I can spot for you
    May 2007
    Jimboomba. QLD
    Update. Replaced the ECM relay and problem solved. Thanks for the advice
    Quote Originally Posted by craig_the_german View Post
    Excellent. Did you open up the relay for a look?
    Good to hear you solved the issue.
    2017 Ford Fiesta ST
