Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Supercharger problem
  1. #21
    Apr 2010
    Found the cause of my problem yesterday - someone had used a knife or screwdriver to remove a hose in order to access something while servicing the car - there was a 3cm split there. Replaced the small hose with one from another car and that's one problem solved. The part probably would only be worth $20 but I'm sure VW would've exaggerated the problem (and the cost) if I got them to fix it.
  2. #22
    Nov 2009
    SEQLD
    That's good to hear that it was nothing major. What other problems are you having?
    MY20 Golf GTI TCR
    MY20.5 LR Defender P400 HSE
  3. #23
    Apr 2010
    Coolant pump is seeping a tiny bit - grabbed one off another car and will replace that another day. Apparently the engine mount isn't as sturdy as it should be, and I can something feel the tiny movement when going on and off the gas pedal, but had the car on a hoist yesterday and couldn't spot any issues.
  4. #24
    Nov 2009
    SEQLD
    OK, so nothing to major then. How many Kms you got on it now?
    MY20 Golf GTI TCR
  5. #25
    Apr 2010
  6. #26
    Hi, I have replaced my water pump but my supercharger/belt isnt moving! How do I check if the fuse is blown? How do I replace the fuse for the Supercharger and where is it located?
    I have a 1.4 tsi scirocco 160 hp 09
    Sent from my SM-G975F using Tapatalk
