Results 1 to 7 of 7
Thread: Does Optima D35 fit Battery Box
    Oct 2011
    Chingwyn, Vic
    Original Varta battery ( 5KO 915 105D) is struggling a bit and will probably soon go off to rest. Sitting at 11.5v most of the time (12.1v after 24 hr charge with CTEK) , but still starts the car, I expect this Winter will be the end for it.
    I like the Optima D35 Yellow, just because I think it might last longer than the 5 years I have gotten from the Varta (not that 5 years is bad). Also, I often listen to the Stereo without the engine running.
    I like the neat fit of the Varta battery, it is 240 x 170 x 170, so will the Optima fit in nicely and will the hold down brackets work?
    I couldn't be bothered buying a new battery box or anything like that, so would get another Varta if it is not a drop in fit for the Optima.
    Anyone fitted a D35 ?
    Thanks
    Digger
    Pacific Paradise QLD
    Quote Originally Posted by Digger11 View Post
    Thanks
    Digger
    Have you looked up its specs No doubt the size will be there
    Jan 2010
    Condell Park, NSW
    Battery size of original in your car is a DIN 55... The battery you want to fit has the same footprint but is 25mm taller...
    I own a diesel which takes a DIN 66 (which aside from the bigger footprint is the same height as the battery you want to fit - 195mm)... No bonnet clearance issues...
    Should be OK...
    - Anthony
    VW Tiguan 110TSI Life | Tungsten Silver
    Dec 2012
    Sutherland Shire, Sydney
    Quote Originally Posted by hoi polloi View Post
    The optima has a base tray which makes the battery more versatile, keeps the terminals at the original height of tall batteries, but you can remove it for a normal fitment
    Oct 2011
    Chingwyn, Vic
    ok, thanks
    Jan 2011
    Brisbane - QLD
    Thanks
    Digger
    mine
    MINI Cooper S Clubman - FWD
    Oct 2011
    Chingwyn, Vic
    Bought the yellow top, fits fine, even the oem battery cover fitted. About $300 which is good too.
