Does anyone know how to make the LED tail lights pulsate like the following videos ?
‪VW Golf R by autocar.co.uk‬‏ - YouTube
‪LED tail light install in MK6 MKVI Golf‬‏ - YouTube
It's a similar issue to when video cameras film TV screens. The frame rate of the camera vs that of the screen causes flickering. Same with LEDs. They're not really pulsating like that...
Ya coreys right, i see it alot on top gear & fith gear
Yes, that's true.
GTI BY & MY 12.5 - 5 Door
DSG, Carbon Steel, Bi-xenon, 18inch Detroit, ACC, Sunroof, RVC, Leather, Dynaudio & Window tint. GOT IT
Can't remember where I copied this from. But here it is, apologies if I ripped it from someone here:
Volkswagen Golf Emergency Brake Warning Flash
When braking in an emergency the hazard lights flash to warn traffic following behind.
This feature can be turned on and off in Vagcom/VCDS using Byte 17 Bit 0.
For the lights to flash the following parameters must be met
• Deceleration has to be higher then 7m/s² and
• for a duration longer then 700ms or
• the ABS must be active for more then 2 seconds.
Once one or both of these requirements are met the indicator lights will flash until the parameters are no longer met.
you can also select whether you want brakes and/or hazard lights to flash
Did you guys actually watch the videos?
The first R is definitely some kind of special effect set up within the tail light module as both sides sweep at the same time, and the front LEDs don't flicker at all.
The second video just looks like two seperate photos that have been swiped together to create that effect.
2002 Volkswagen Bora V5 - 2007 Mazda 3 GT - 1998 Ford Contour Sport - 2010 Volkswagen Jetta 2.0T - 2013 Volkswagen Passat 130TDI - 2015 Ford Escape 1.5 - 2016 Subaru WRX - 2018 Volkswagen Golf R Wolfsburg Wagon
Yeah... that's not what the OP is asking about.
Sure I did. My first post still stands. This isn't anything unusual and has occured for decades with cameras and certain types of light sources. There are other threads around the forums which have argued this too, only to end up at the same conclusion.
Want more proof?
Look at the first video again! That was the international launch of the Golf R at the Frankfurt Motor Show! Do you really think that Volkswagen would have modified the Golf R to have some super special fancy tail light effects for the FIRST PUBLIC LAUNCH of their new Golf flagship? Think about it![]()
Wiring in a "racing lights" module for LEDs is done in various display units we use at work
Should be possible on the VW
I would suggest VW did just that for the display vehicle for effect
8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
