Results 1 to 8 of 8
Thread: Fault code P10A9
masterkenlee9 Fault code P10A9 08-07-2016, 08:16 PM
Snail Style Most likely fault is going... 09-07-2016, 08:25 AM
masterkenlee9 so.....the car is checking... 11-07-2016, 07:01 PM
masterkenlee9 Hi All, Finally. the... 15-07-2016, 02:19 AM
mazzer Hi do you have the parts... 23-04-2017, 09:57 PM
Umai Naa!! Water pump/supercharger... 23-04-2017, 09:59 PM
PeterHattam How much approx. was the... 02-10-2021, 05:29 PM
Guest001 Thread is 5 years old OP may... 02-10-2021, 07:34 PM
    Jul 2016
    Hong Kong
    Fault code P10A9
    Hi,
    I am from Hong Kong, and i bought a second hand golf GT (2011) at last month.
    Last night the engine alert light is on (orange).
    Today i replaced the Carbon Canister. the alert is off. so I turn off the car.
    after 1 hour, i install the Cam recorder iRoad V9. after the activity, i turn on the car and see the engine alert is amber again,
    Fault code P10A9 is showing in PC. I check some information in Internet.
    Supercharger (SC) clutch - does not open"
    Would anyone provide the solution to me?
    Jul 2012
    Sinagra, Western Australia
    Most likely fault is going too be a failed water pump or wiring to the unit itself.
    Volks Handy
    Servicing - Repairs - Diagnostics - Mobile fault scanning/clearing - A/c work
    10 years experience working for Audi/VW/Skoda
    Now in Perth NOR, Western Australia.
    Jul 2016
    Hong Kong
    so.....the car is checking now....the guy from factory said fault from the charger dump.
    and i will update here if problem fixed.
    Jul 2016
    Hong Kong
    Hi All,
    Finally. the problem is fixed now.
    I replaced below parts. Hope it will help you.
    Attached Thumbnails Attached Thumbnails Fault code P10A9-20160712_181747-jpg
    Apr 2017
    Brazil
    Hi
    do you have the parts name ?
    cheers
    Quote Originally Posted by masterkenlee9 View Post
    Hi All,
    Dec 2008
    Sydney/Canberra
    Water pump/supercharger clutch assembly.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Dec 2020
    How much approx. was the repair cost?
    Pacific Paradise QLD
    Thread is 5 years old OP may have died in the meantime
