Page 1 of 5 123 ... LastLast
Results 1 to 10 of 49
Thread: Sick Golf R - EPC and flashing engine lights on (SOLVED: Fuel Injector)
    Mar 2007
    Country NSW/Southern Tablelands
    Driving home yesterday my Golf R's engine started missing when placed under load. Thought it may be dirty fuel or a bubble or something as it went away after 3,000rpm, but was still down on power.
    Going up a hill a little later the car starts missing and stuttering again with a big drop in power. The yellow engine light started flashing so I pulled over and turned it off to consult the manual as to what it meant. It said that the engine was missing and causing problems with the catalytic converter - take to dealer.
    Rang dealer and booked in for Monday morning (it would happen on a Friday). Started off again slowly then the EPC light came on. Drove home very gingerly with everything turned off. Along the way I noticed that the engine started missing when under load below 3,000rpm. Using the paddles I kept the engine above 3,000rpm and it didn't miss. Didn't sound right though and still down on power.
    Anything I should tell the dealer on Monday morning to look for, assuming I can get there under my own power?
    Thanks Guys
    PS: MY10 with 84,000kms on it.
    Man In Black (MIB)
    2007 V6 4Motion Passat, Black, Leather, DSG, 18" Wheels, Bi-xenons
    2010 Mk 6 Golf R, 5-dr, Rising Blue, DSG, leather, ACC, RVC
    Mar 2013
    Brisbane QLD
    not really had any issues with golfr.... its been a good motor so far... hard to tell without getting a fault code read out... VDUB....
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Ignition coils id say. They are a common failure item on these engines and if you are still running the stock ones after 84,000km then id say thats it. You can get a full set delivered from USA for about $130 so you don't need to pay the ridiculous dealer prices (they charge over $100 just for x1 coil).
    Mar 2007
    Started her up this afternoon for the first time since friday when I limped home and low and behold no problems. Took her for a drive expecting more flashing lights and failing systems than Jack Lemon in The China Syndrome but nothing?? WTF is going on??
    Man In Black (MIB)
    Mar 2013
    Brisbane QLD
    could have been crappy fuel or if it is the ignition coils sometimes they only break down randomly especially when hot.. Or could have been a electrical sporadic issue like a wiring pin etc that caused a issue that has now moved or corrected itself... still worth finding out what fault code it logged even if the fault doesn't return, it will more than likely happen again and you don't want to be in the middle of no where when it happens... Get it scanned as it will have remembered the fault code even if the light has gone out.. It will at least put you mind a rest to see what it was..... VDUB...
    Arrawarra
    You can get the torque pro app & obd II bluetooth dongle for about $20, cheap as & good for running a scan yourself! The error code will still be there to retrieve...
    Jan 2011
    Brisbane - QLD
    Bought a mini one fr ebay and i keep it in the car. Very handy for at least finding out what the CEL is all about.
    Quote Originally Posted by MGV View Post
    Mar 2007
    Lucas-R, spot on Mate. Had the car checked over today and all the indicators are an ignition coil. All four being replaced.
    Car started missing again tonight as soon as a load was put on while the engine was hot. I was told that when the computer senses a missing cylinder it turns the fuel injector off. Saw that tonight as my fuel economy was better than I'd seen it for a long time, and that was despite deliberately keeping the revs high manually to avoid putting a load on it.
    Man In Black (MIB)
    Good to hear - a common issue thats easy to fix. Are they changing them under warranty or is it coming out of your own pocket?
    Sep 2009
    seaforth, nsw
    yes, interested to know if u fall under warranty, being a 2010 with 84k km.
    i had coilpacks go out in my 2011 gti with 27k km, but they replaced all plugs and coilpacks under warranty
    2011 cw golf gti 3dr man-tint-rear cargo mat-weathershields-bluetooth-mdi-19" oz racing ultra leggera-mcgard lockbolts-boston acoustic pro60se-jl audio xd700/5-jl audio bass tube bb-w060p- titanium exhaust tips-eibach custom pro-kit-OPS-OSIR cf mirror covers and cf front lip-dieselgeek short shifter
