Originally Posted by
Ferni
My VW dealer said to be careful installing this part, as since it isn't a certified fix by VWA, if for some reason this part causes issues, ie holds the actuator closed and you run unlimited boost, blow your engine and not covered under warranty. While this is pretty unlikely, if something did happen to your engine, you could be in for a fight...
My next step is to escalate to VWA, and keep escalating until a satisfactory answer is received. There is always an escalation point, up to the CEO in Germany.
