Results 1 to 8 of 8
Thread: MK6 GTI fuel gauge problems
    Jan 2008
    Sunshine Coast
    Hi all,
    I have a mate with a out of warranty MK6 GTI. His fuel gauge has started playing up, suddenly dropping to empty with half a tank, seems the sender has packed it in. Do you have to get a whole new assembly at $400 odd, or is there a particular sensor that plays up?
    I get that is seems to be a common problem, just wondered if anyone has some info on a less pricey fix! For sure you can get a used part, but then how long till it plays up.....
    thanks in advance,
    Greg.
    Dec 2008
    Sydney/Canberra
    You can buy the sender unit for the gauge on it's own.
    1K0919673AM
    Aug 2019
    Brisbane, Qld
    Is this part number correct? Where can I buy one?
    Aug 2019
    Brisbane, Qld
    From what I can see, only thing I can do is buy entire pump/sender unit....
    Jul 2012
    Brisbane, Queensland
    Just a heads up on this issue. I think it’s the same as what I had and it was actually the sender loom connector. Mine got re-wired which fixed the issue from memory.
    MY12 Golf R | 5 Dr | Deep Black | DSG | Discover Media retrofit | RVC retrofit | DYNAUDIO
    Aug 2019
    Brisbane, Qld
    Quote Originally Posted by aswigon View Post
    OK, I might pull the seat and check.. it is an intermittent problem so really not sure if the sender is bad. Will wiggle some wires when I get the car back.
    Take the pump out and give the sender a clean up. I have given them a bit of a buff with metal polish. Then blast with brake cleaner.
