Results 1 to 5 of 5
Thread: messed up vcds
    May 2022
    Auckland
    messed up vcds
    Hi All
    So i thought i could set my mirrors to auto close with the door close and now i stuffed something up.
    if i push the lock on my key the windows used to go up now they don't
    the door mirrors used to flash with the indicators now they don't
    rear door windows dont go up or down anymore and i see Status: Cannot be reached 1100
    if i set setting in vcds on the front left then the right left mirror will flash so left is controlling the right ect:
    Mirror control has also changed from right to left and left to right side
    I don't have the code to set codes in security access but can under coding (single)
    i have checked and the car is set to right hand drive under gateway
    any one know what i have messed up
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    2E-Media Player 3 -- Status: Cannot be reached 1100
    37-Navigation -- Status: Malfunction 1010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 1110
    57-TV Tuner -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: Cannot be reached 1100
    May 2022
    Auckland
    ok figured it out
    when you do the coding you need to add all the options together
    :folding mirrors code plus driver side and what ever else you need ect:
    2 + 4096 + 32 = 0004130
    • +0000001 = Rear Lid Remote Unlock Button (E233)
    • +0000002 = Ambient Mirror Illumination
    • +0000004 = Mirror Turn Signals
    • +0000008 = Interior Door Handle Illumination installed
    • +0000016 = Automatic Run active
    • +0000032 = Mirror Heater installed
    • +0000064 = Door Exit/Warning Light installed
    • +0000128 = 5-Door Chassis
    • +0000256 = Seat Memory installed
    • +0000512 = Right Hand Steering
    • +0001024 = Safe-Motor not installed
    • +0002048 = Pinch Protection inactive
    • +0004096 = Folding Mirrors installed (MY 2008+)
    all modules pass now
    Dec 2006
    Kilsyth, VIC
    Awesome work figuring it out yourself (I bet a lot of frustration and googling!).
    It's always best to keep a log of what you have changed and the original values so you can go backwards if you ever misconfigure something.
    Sadly when it comes to coding I've found that lots of options require different sub modules that may or may not be present in different countries (and sometimes even different cars of the same model). This means that you can turn stuff but it doesn't work and usually there is no way to know without trying.
    It doesn't help that Australia is a (relatively) small market and lots of the information is out of the UK or the US and things are just that little bit different here.
    Pacific Paradise QLD
    Quote Originally Posted by allann View Post
    Hi All
    Isnt there a history file that you can revert to.
    ALWAYS BACK UP BEFORE YOU DO ANYTHING
    Dec 2006
    Kilsyth, VIC
    You would think I should know the answer to that by now But I've only ever really changed one thing at a time so never really bothered to learn.
    But yes, there are options:
    Back up of current car settings - VCDS | Ross-Tech Forums
