While the 6 speed DSG can suffer from similar mechatronics issues to the 7 speed, it doesn't seem as common. And the 6 speed definitely doesn't have the clutch shudder issue that the 7 speed can suffer from (wet clutch vs dry clutch may be the reason).
I have the 103kW TDi MkVI with DSG and it is terrific at longer trips - you barely notice it is a diesel except at a slight rattle at idle, although the 118 TSi engine is a touch smoother.
Resident grumpy old fart
