Results 1 to 4 of 4
Thread: Mk6 money pit…
    Mk6 money pit…
    2012 Mk6 GTi DSG. 147km. Whining in 1st and 2nd. Took it to lube mobile, who removed the box and took it to transmissions r us in Perth, and apparently needs bearings replaced and a new clutch. Quoted $6000 all up.
    I’ll keep it simple, am I being ripped off? Can I put in a used DQ500 with clutch for less than $6000 or is that not possible?
    I don’t have time to do the research myself. Hoping some legends on here can help me out.
    Thanks in advance.
    Mornington Peninsula, VIC
    I am sure a 2nd-hand, low km DQ250 installed would cost a lot less than that; how long has it been making the noise? When the bearings go they tend to spread metal shavings around see Golf R 4MOTION DSG DQ250 Tapered roller bearing replacement - YouTube
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    As above - i wouldnt bother rebuilding the existing gearbox. There are heaps of DQ250 gearbox's around from crashed cars....id be grabbing one of those and throwing it in.
    DQ500 is a bit of a rabbit hole money pit type situation. Would only persue that if you can find someone who has done several conversions already and knows all the tricks and traps.
    Quote Originally Posted by Ishouldntbedoingthis View Post
    Thanks in advance.
    Fitting a DQ500 wouldn't save you anything. All kinds of dramas to make that work.
