Thanks mate
Enjoying the vehicle apart from a few little issues. Some fixed, others about to be.
Ended up with the extra factory warranty tacked on. Will definitely enjoy that !
Printable View
Thanks mate
I'm pretty sure this would have been covered at some point, but I don't even know what I'd be searching for. Imagine you're standing infront of the Golf R looking at the front of it. On the passenger side, below the LED DRL, that area is open. Inside there is a cooler of some kind.
What is that? Oil cooler? DSG oil cooler?
I've been told numerous times that it's a DSG oil cooler.
But then I'm sure one of the manual boys said they still have it.
Considering the Golf R's oil temp is quite a bit cooler than the GTI, I think it's an additional oil cooler.
Hmm.... so that would probably need to be emptied during an oil change?
I was going to attempt my own oil change this weekend on the R. I wonder if it's more difficult than I first thought.
Nah....
Just follow the instructions in the service manual.
You can get that from erWin for only 4 euro....
That cooler in the Passanger side front guard is the DSG Cooler. The Manual R just has a duct to direct the air toward the gearbox, no cooler...
That cooler is on most late DSG's, and some manuals. Some R32's had it, some didn't.
Its actually plumbed into the entire cooling system, not just the DSG cooler, so the DSG cooler runs at engine operation temperature. If you log your DSG oil temps, you can see the change in them when the engine thermostat opens.
So it really is an auxiliary radiator.
Hi Big Dave
I can't acces the youtube vid - at work grrrrrrrrrrrr, but well done. I've done a few days with Paul years ago, with my 02STi when he started it up, and he runs a very good day.
What power do you put out and what times wre you putting down in the Golf R. Interested as I've just bought a 3dr DSG model.
Cheers Paul
"Golf R Stage 2+, I couldn't overtake the stock xr5 on the straight"
I watched the clip and you weren't really gaining much on the straights vs the 166kw XR5 which is a big surprise.
If just a chip gives 239kw then i gather 2+ would be around the 270-280kw mark? Shouldn't you have wiped the floor with the XR5 given you have nearly double the power?
You'll find that answered in the tuning forum, but Stage 2 isn't about huge increases in peak power over stage 1, it's about optimising what you have and widening the torque and power bands.
But directly related to the R vs XR5, it's been shown again and again that the R's advantage is in the 0 to xKm runs and not around necessarily around a track (at least in the dry). In rolling acceleration, a GTI with the same power runs away...
