After a few months of waiting my APR Stage 3 kit arrived a few weeks ago, and after a week of work I finally picked it up yesterday.
In case anyone else is thinking of this upgrade (and you should be :biggrin:) here are a few impressions from my first few days with the upgrade:
The Kit: The upgrade consisted of:
•Stage 3 Turbo kit - Garrett GTX28xx turbo, new intake manifold and plumbing to suit
•Bigger intercooler
•High & Low pressure fuel pumps
•Full turbo back RSC exhaust
•Runner flap delete
•ECU and DSG software
Power: The power is, as you'd expect, amazing. We haven't put the car on the dyno yet - APR recommended putting a few hundred kms on it first - but the specs say it should be somewhere around 315kW at the flywheel. Keep in mind I came straight from a Stage 1 chip (no hardware) to the full Stage 3 kit so it's a big jump on this car.
The Autopolar boost gauge shows about 30 PSI peak boost.
Performance: First run 0-100kph in 4.1 seconds.
Drivability (Normal Mode): My big worry was that Stage 3 would 'ruin' the car (my wife's words) in much the same way I 'ruined' my Polo (ie made it fast but also very loud, laggy and annoying to drive on the street). Thankfully there was no need to worry at all.
Basically if you keep the car at less than 4000rpm then it's just a Stage 1 tune. You can drive around town quite normally using 3/4 throttle or less and it behaves very much the same as it did before the upgrade - nothing obnoxious, loud or unexpected.
Drivability (Manic Mode): On the other hand, keep it above 4000rpm with a heavy right foot and the car changes character completely. The smooth acceleration to redline and muted exhaust note of the stock car are replaced with a brutal kick in the back and an amplified version of sound you hear when you pull a running creepie crawlie out of the bottom of a swimming pool.
Once you hit the boost level it's easy to keep the car in this zone, and the power delivery will be perfectly suited to the drag strip or race track where you can keep the car on boost.
The bad part is when you want to drive between the two modes - for example when you want to take off quickly from the lights. In this instance you get Dr Jekyll for a few seconds until you reach 4000rpm in 1st, and then Mr Hyde as you jump from about 15 PSI to 30 PSI almost instantly. This means the SS Commodore next to you gains about half a car length before disappearing behind you very rapidly in a cloud of tyre/clutch/exhaust smoke.
Cons: Other than the new bi-polar personality of the car (which is an improvement on the zero personality you get in a stock R) the only real issue so far is with the DSG. The extra power is confusing the DSG - even though it's got the updated APR software it is having a hard time handling the sudden rush of torque when the boost hits, and Launch Control instantly sends the DSG into overheat warning mode.
I suspect some of the issues will be resolved with software tweaks but I was already considering doing a DSG clutch upgrade so will probably go down this path anyway.
A few pics along the way:
Engine out ready to work:
http://www.vwwatercooled.com.au/foru.../2e5l0t0-1.jpg
New Turbo installed - Garrett GTX2767R:
http://www.vwwatercooled.com.au/foru.../28wj52w-1.jpg
Engine back in the car (sorry for the blurry pics - they're great mechanics but not so great photographers :))
http://www.vwwatercooled.com.au/foru.../2z8qiog-1.jpg
APR full RSC exhaust:
http://www.vwwatercooled.com.au/foru...3/51dc1y-1.jpg
