Interesting read WJ.
Would you say if you went from OEM 17" to lightweight 18" there would be almost no compromises to the factory suspension and would you need ACC?
Is that how it would work or would you need to replace the whole damper anyway? Was also wondering the replacement cost down the track of VW ACC suspension and which parts you'd be locked into using and may not allow you to use after market bits later? Just a though as OEM replacement parts are usually quite hefty.Quote:
Other advantage of ACC in the longer term is that as the damper wears down, and losses its resistence & effectiveness, you could run ACC in sport all the time to create that new car feeling of firmness & agility.
It's easy to justify each option but could end up ticking every box that way.
