Would it be viable to get Xenons fitted at the dealer after pick up ?
Printable View
As well as the headlight washing system.
I'd have thought the self leveling motor was actually part of the headlight assembly. So you just have to add the washer jets. With the MK6 this isn't AS hard as it was on the MK6 since the provision on the front bumper is already in place (on the GTI anyway). But yeah - it's just a PITA. If you want Xenon - get it on the order.
Other parts to be fitted include
level sensors on the front and rear sway bars (sensor mounts on the chassis and wiring back to levelling controller)
new water tank
additional electric pump in water tank (additional wiring back to under dash)
additional sensor in water tank (additional wiring back to under dash)
additional wiring to headlights (additional wiring back to under dash)
new connectors for headlights
levelling controller plus various connections including to canbus
coding of unit
fitment of pop out washers
removal of front bumper
mods to front bumper
and the list goes on.....
Ok, so it looks like xenons are out of the question for me... :(
The only thing i really miss is the RVC, can that be done at sau JB or someplace else?
Thanks for the info Mav :)
JB aren't able to fit them but you should be able to find somewhere like Volkspower in Melbourne and European Autotech in Sydney.
Installing a Golf Mark VI Rear View Camera (RVC) into a Golf Mark V
http://www.my-gti.com/1423/
(the procedure on the Mark VI is almost identical except you don't have to cut the metal and a slight change to the wiring)
