Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Wheel upgrade....your advice please.
    Apr 2012
    My golf 90TSI comes with 15" alloys and 195/65/r15 tyres, can i upgrade them to 17' alloys and 225/45/r17 tyres? any effects (positive or negative) on ride quality and fuel consumption? Glad to be advised!
    Oct 2010
    Melbourne, VIC
    Grip will be improved on smooth surfaces.
    Fuel economy and ride will almost certainly suffer and tyre replacement costs will go through the roof.
    If the 17" wheel/tyre combination is much heavier than the OE (almost guaranteed unless you are VERY careful with your wheel selection), then acceleration, braking and turning response will be slower due to the increase rotational inertia and grip on bumpy surfaces may be reduced plus ride will further degrade.
    Resident grumpy old fart
    Jan 2009
    Quote Originally Posted by OYE View Post
    Well, in terms of ride quality and fuel consumption, the effect of bigger wheels and tyres is almost always negative.
    Lower profile tyres means less compliance in the sidewall, and wider tyres can increase fuel consumption.
    Bigger wheels and tyres are also heavier, meaning an increase in unsprung weight - unless you buy very light and very expensive wheels. This effects both ride quality (suspension has more work to do) and fuel consumption (more mass to move).
    Quote Originally Posted by kaanage View Post
    ... and tyre replacement costs will go through the roof.
    Ah, also a good point.
    Jun 2011
    Check out this thread:
    mk6-77tsi-17-wheel-problem-help
    It was Dave's comments re ride quality in the end that kinda put me off changing my rims:
    Quote Originally Posted by bigdave260 View Post
    Capt.: Significant change in the ride going from the 15" to 17" wheel, I would say the car definately rode better (more smoothly) on the 15's but felt less planted and definately didn't perform as well but i think this is more to do with the width change from 6 to 7.5. I'm glad i didn't go to 18s as I think this would make the ride too harsh on my suspension (non-sport) and i didn't want to have to play with camber if the wheels were 18x8's.
    captain courteous enjoys vag
    Erskineville, NSW
    +1 to what kaanage said. Try & keep your ET between 45-52 or you'll get too much poke.
    Maybe go for the happy medium of 16" rims?
    Look through eBay & the various VW forums for people that are selling 16" rim/tyres that are unmarked & almost new.
    I have 16x7.5 ET51 Audi rims with 225/55x16 Michelins (they made the speedo deadly accurate) - they cost me $400 off eBay + $10 for badges & $10 for hub-centric rings (late Audis have bigger hubs than VW/Skoda). When they are worn out I'll buy something different off eBay or a forum. This is the 3rd set of rims I've had in 95,000km.
    Apr 2012
    Thanks kaanage, it's clear to me now.
    ---------- Post added at 01:26 PM ---------- Previous post was at 01:20 PM ----------
    Quote Originally Posted by Diesel_vert View Post
    You definitely nailed it Diesel_vert; ride quality and fuel economy are two things i can't trade for anything. Thanks a lot.
    ---------- Post added at 01:37 PM ---------- Previous post was at 01:26 PM ----------
    Quote Originally Posted by Captain Courteous View Post
    I agree with you Captain!
    ---------- Post added at 01:38 PM ---------- Previous post was at 01:37 PM ----------
    Thanks Brad, but don't you think 16" still means more weight than what i currently have?
    Erskineville, NSW
    proabably if you go genuine VW OEM. Mine are a porky 20kg and I know if I spent some reasonable money ($2k tops) I could knock 5kg off that easily.
    Maybe you should weigh your current rim/tyre combo as a baseline & compare with the bigger sizes?
    If you look at the (limited) range on tirerack, 17x7.5 Enkei come in at 6.9kg but the lightest 15" rim they have is 7.7kg & the lightest 16" Sparco is 7.4kg. Of course if you buy based on looks & price then you might be looking at double those weights.
    Buy a good lightweight rim & a lightweight tyre (there's about 1kg variation in a given size) and it will be win-win all the way.
    Apr 2012
    This is very interesting Brad, i used to think bigger rims always means more weight, but now i know better. I'll give VW OEM a serious consideration then. Thanks a lot.
    Erskineville, NSW
    No, I meant genuine VW OEM is usually a bit heavy. They have to make them to a price & also be strong(ish) therefore they are usually a bit heavy.
    Sep 2009
    seaforth, nsw
    honestly, the weight difference going from a 15" to a 17" oem rim would be about 2-3 kg a tyre/rim, thats about 10-15kg total. which is a load of shopping, which is buggerall. u could even out the "fuel consumption" by driving more efficiently, inflating ur tyres, etc.
    ride will become a little harsher, but seriously, how cushy do u want it?
    i went from the 17" denvers to a 19" oz racing rim. sure its a little stiffer, but ive driven performance cars (evo9, s2000, wrx, etc) for many years, so driving a "euro" is like heaven for me, the ride comfort is that much better than any of the previous japanese cars ive owned, even with the 19" rims and rubber band tyres.
    ur two main concerns are fuel use and ride quality, which are understnadable, but to me thats a none issue, fuel use can be negated by driving smarter and keeping ur car serviced and running well at all times. upgrading rims and tyres will have minimal effect, maybe half a litre per 100km. ride comfort, thats also a non issue for me, if u have ever driven ****boxes and japanese cars, then the golf in itself is a great place to be sitting.
    the positives of going to a bigger rim outweigh the negatives, better contact patch and better handling from more rubber.
    tyre cost will be at most $200 extra every 40000km, 15" tyres are about $150-200, 17" tyres are $200-250.
    think bigger picture please
    2011 cw golf gti 3dr man-tint-rear cargo mat-weathershields-bluetooth-mdi-19" oz racing ultra leggera-mcgard lockbolts-boston acoustic pro60se-jl audio xd700/5-jl audio bass tube bb-w060p- titanium exhaust tips-eibach custom pro-kit-OPS-OSIR cf mirror covers and cf front lip-dieselgeek short shifter
