Results 1 to 6 of 6
Thread: Which model do I have?
    Jan 2017
    Sydney Australia
    Hi,
    have recently purchased a late 2011 (first reg'd 2012) model turbo diesel, for my Daughter as her first car.
    Apart from a year range, I can't seem to find in the forums, what I have.
    As I mentioned, it is a late 2011 model and the compliance plate shows Model 5K1 and Type 22N.
    Does this make it a Mk6?
    Which is the most appropriate forum for my research on this car. Any replies of assistance are much appreciated.
    Cheers Fireup01
    Pacific Paradise QLD
    Should be a sticker on the B pillar or in the boot with the build date on it. Be aware with a diesel it needs a good hot run often or the DPF will soot up and they arent cheap.
    Not a car for a tootle to work each day
    It must also be filled with VW approved 504/507 grade oil VW use Castrol professional III at huge prices. You can buy stuff like Penrite Enviro+ or a different Catstrol Edge for a lot less and supply your own at oil change time.
    Dec 2008
    Sydney/Canberra
    5K1 is a MK6 Golf.
    Jan 2017
    Sydney Australia
    Thanks Hillbilly, that's a great bit of info right there. I had a look and it is a little confusing, as the two tags say different info:
    On the B Pillar it says: Built Sep 11, Model 5K1 and Version 22N
    In the boot it says: 01/12 and type 1K
    Quote Originally Posted by Umai Naa!! View Post
    5K1 is a MK6 Golf.
    Thanks Umai Naa!!!, you have confirmed what I was thinking it might be. Cheers for that.
    Quote Originally Posted by fireup01 View Post
    So its a Sept 11 for registration and probably insurance and it was complianced in Jan 12.
    Jan 2017
    Sydney Australia
    Yes that makes sense Hillbilly, thanks for that.
