Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: 7 sp DSG 400Nm?
    Dec 2007
    Quote Originally Posted by cme2c View Post
    Which brings me back to my original point. What 7 speed DSG is VAG going to use in the transverse engined transporter and could it be grafted to the Golf etc?
    Haha, which brings me back to my last post -
    "I read today something along the lines of "VW has had to beef up their DSG box to suit" http://www.carsales.com.au/reviews/2...neration-16785
    So I looks as though there is plenty of potential in the 7 speeder with dry clutches.
    Would that mean the dry 7 speeder will eventually replace the 6 speed oiler across the entire range where the donk is a high torque one?"
    2008 Blue Graphite GTI DSG with Latte leather. SOLD 4/9/2024
    2023 T-ROC R - Sunroof, Black Pack, Beats Audio
    Sep 2009
    Quakers Hill, NSW
    Quote Originally Posted by gerhard View Post
    That would be a good thing. OTOH, is the "beefing up" real or have they not changed anything except the spec sheet, crossing out 250Nm maximum and substituting 400? APR seems to have no problem putting 300+ Nm through the 7 speed dry clutch DSG with their 151kW 1.4 twincharger reprogram. This is relevant to me as a 118TSI DSG is off the boat and (slowly) heading in my direction. Also, the reduction in complexity and servicing costs with the dry clutches vs wet would annoy me if I had bought a 103TDI.
    Dec 2007
    You could be right there, VW quotes a spec which in the case of both the 6 and 7 speeders is way below the danger level.
    The "beefing up" is probably only to the clutch spring strength, similar to what APMitchell has done on his turbo R32, now feeding 500+hp through the DSG (and way more than the 350nm specc'd limit).
    The servicing cost of ~$400 for the 6 speed DSG every 60,000k is not excessive by any auto transmission service standards. But the lesser cost of the 7 speeder is better still.
    Aug 2009
    Melbourne, Vic
    Could it be that the 250Nm "limit" is not to do with stress on the gearbox per se, but instead, its ability to reliably change gears in a smooth and satisfactory fashion? So while it can cope with the extra Nm's without fear of damage, the average user may not be satisfied with the quality and smoothness of all the changes. Planned improvements to the software controlling the DSG may be able to alleviate this. Just a thought, based on limited observations with my tuned car.
    Sep 2009
    Quakers Hill, NSW
    Last 2 autos we had(2003 Peugeot and 2007 Honda) both had transmissions that were sealed for "life". Servicing costs zero. Of course, if it broke that would be expensive.
    Dec 2007
    Yes, my Jackaroo has a "sealed for life" transmission also.
    Believe it at your peril I have serviced that "sealed for life" auto every 50,000k with a filter kit and fluid replenishment. The transmission is identical to the earlier Jackaroos, which were not rated as "sealed for life". So how can an identical transmission receive a different engine in front of it and become magic for life? - it can't......and it doesn't.
    Those on the Jackaroo forums who have never changed are whinging loudly about the $5000 repair bill due to the fluid being worn out and filthy, causing failure.
    Sep 2009
    Quakers Hill, NSW
    Quote Originally Posted by logger View Post
    That's interesting, logger. So, you've noticed a difference between standard and tuned. Maybe the map for the DSG needs to be altered too (or perhaps it has been) In these days of computer controlled engines, torque limiting on changes doesn't seem that difficult. We have autos that blip the throttle on downchanges, after all.
    I've seen clutches explode and I remember when Holden stuck an Opel box behind sixes and IIRC small v8s. Disaster ensued. How does torque damage gearboxes? Is it a limit to the strength of the gear teeth? Stress on bearings? end float from helical gears? not being an engineer, I dunno.
    Jan 2007
    South Australia
    Just finished reading the full T5 press release from what I read the 7spd DSG unit is brand new developed for the LCV family.
    So future Caddy and possibly Amarok models may receive this unit in future no doubt.
    - Ben
    1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
    2008 Jetta 2.0L FSI
    Sep 2009
    Quakers Hill, NSW
    I did put life in quotation marks. I agree that there is no magic Lubricants have improved but there are still clutches, bands etc. and gears that put shear forces on the fluids. Both of my earlier cars were traded in before 50000. Life as far as most manufacturers is concerned is the end of the warranty.
    Sep 2009
    Quakers Hill, NSW
    Quote Originally Posted by phaeton View Post
    If it fits in a Caddy it will probably fit in a Golf. The Anorak is much bigger of course.
