118TSI - Appreciation & Thoughts
I think older 118 had bad spark plugs leading to misfires that weren't detected by the driver. Years down the road engine failure. Haven't really heard of engines with the new spark plugs getting this issue.
Quote:
Originally Posted by
Sentinel
I've had the pistons and injectors replaced, but as far as I can tell I still have the old spark plugs. I need to do something about that.
A thing to note is that you can change the gap on them and you would be ok. The gap should be 0.8 mm according to Vw. Older plugs came gapped at 0.9 mm
brad
If 0.1mm (0.004"??) is the difference between the engine grenading & staying together then it must be more finely tuned than an F1 engine.
The misfire that occurs is very small. Mostly unnoticed by the driver. An engine that is seemingly running fine is misfiring unbeknownst to the owner and is being damaged slowly. Spark plugs are finely tuned things anyway. 2mm is a lot with spark plugs.
