Results 1 to 7 of 7
Thread: Mk6 Golf R with high kms
    Jan 2021
    Hi everybody
    I’ve got my eye on a mk6 golf R with 197,000 kms.
    Service history is average with evidence of recent engine oil changes only.
    I’ve listed the following to be replaced up front as a cost, anything else I should be concerned with?
    1) timing belt and water pump.
    2) dsg fluid change.
    3) haldex fluid change.
    4) replaced rear rotors.
    5) fix oil leak front left of engine up high that’s coming from a small cover.
    6) cam follower.
    Worth going for or too risky?
    I can get it for 15k.
    Thanks
    Sep 2009
    south australia
    So many kms and a bad service record , i would stay away regardless of price .
    If it had a perfect service record its still risky , what year is it ?
    GTI clubsport/edition 40 manual white 2016
    Mercedes Benz A200 AMG pack red 2016
    Jan 2021
    Its a 2010 year
    I would probably add PCV and ignition coil packs to the list of things to replace. Both are quite cheap and known to fail on the Mk6 R engine.
    Just as a side note, given the money you are going to spend on maintenenance and servicing on this car - it might be wiser to pay a few grand more for another one with better service history.
    Sep 2009
    south australia
    Is 2010 the year of the suspect timing chain tensioner .
    Quote Originally Posted by spellbound View Post
    Not applicable for the Mk6 R engine as they use a timing belt.
    You are thinking of the Mk6 GTI engine which uses a timing chain and is well known for failing chain tensioners and stretched timing chain issues.
    Jun 2007
    Yes but won't affect this vehicle as it should have an EA113 family engine that has a belt rather than chain.
    06 Jetta 2.0TFSI Killed by a Lexus!
    09 Eos 2.0TSI DSG Loved this car but has now gone to a new home!!
    14 EOS 2.0 TSI has arrived!
