Tiguan sunroof is leaking into the side passenger footwell
My tiguan seems to have this problem. Its an 09 diesel auto. I only noticed that water was leaking into the passenger footwell the other night after it had rained. Initially I thought it was because my wife might not have closed the door properly but after doing more research I've found its definitely a problem with the sunroof drains. Because i've only recently bought this car used, I believe that someone might have worked on this previously because the panel on the side of the glove box has definitely been messed around with. Luckily there is no damage that I can see because the water drains down the left panel left of the footwell onto the flooring and since I have rubber mats and water doesnt stick to the footwell interior, theres no damage.
The problem is definitely somewhere near the left water drain hole in the sunroof because water is actually leaking in the roof, I know this because the cloth around the area around the top of the left pillar is wet.
Also i noticed that there was no drain hoses that I could see when I took the panel off next to the glovebox, is this normal? I would have thought they would drain the water directly from the sunroof through a rubber hose to some outlet instead of letting water run through the insides of the car?
Anyways, since car is still under warranty, will VW fix this? if so do I just contact the number on their website?" Customer Care Centre: 1800 607 822 "
Has anyone else had this problem? is so, what was the resolution? how did VW fix this so this no longer leaks?
This problem is really quite a poor design by VW since you can google this problem since the 90's which is quite dissappointing.
Thanks for your help (again :))
