Does anyone have experience in resetting their Parrot Bluetooth. Mine will not synch to my new phone due to "memory full" .. I really don't want to go back to dealer if its a simple fix I can do,
This worked for me also in the document included with the kit
To Reset:
Ensure that the vehicle ignition and radio are switched on. Slowly (keep your finger on the button for at least two seconds) press the “vol-“ and then the “vol+” buttons on the steering wheel alternatively a total of five times each. NOTE: You must start the “vol-“ button first. Once this has been done you will hear the kit reset through the speakers. The kit will then ask you to pair a device. At this stage pair the new phone to the kit
Thanks all for input. The vol- vol+ trick took about 10 attempts but it finally reset
For anybody out there who has the Parrot kit fitted via The Car Kit company:
http://www.thecarkitcompany.com.au/p...name=Connects2
The reset for this kit is different because it uses the "Connects2" reset, not the Parrot.
To reset the memory, you need to hit the "Menu" button on the steering wheel 5 times quickly.
I spent sooo much time trying to reset by alternating the vol buttons and then eventually found the help sheet provided by the installer - had it sorted in 90 seconds... works perfectly with my new iPhone now.
:happydrunks:
Hope that helps! :banana:
