2 Attachment(s)
17 inch VW Steels Powder coated Satin Black
Well, it took me a while to get it organised, i did buy a secondhand set of T6 steels to get powder coated,
But i found out that my 17 inch steels are a higher load rating (950kg) than the standard Aus T6's (850kg) i had to change the tires over to get my rims into get powder coated
I got the Rims back from the Powdercoaters yesterday, they came up damm good in Satin Black.
The powdercoater did a great job, no runs, no bumps.
Attachment 30415
Got the Cargo Vector 2's reinstalled, was tempted to get 225/65 R17 KO'2, But will get the Seikel Suspension fitted, as QLD Transport won't allow both unless i undergo engineers testing for the ABS and ESP:(
They only have tests for suspension and tire increase up to 50mm, but didn't do both together up to 50mm for both, so unless you pay for the testing, its not legal to have both.
Attachment 30416
Not the Greatest photo, as there is sitting in the shade this arvo, and the wheels need to be cleaned after the tires where refitted.
Will Plasti Dip the Wheelchair Lift panel black under the sliding door, as the powder coat will be damaged after using the lift, (the front swings down onto the ground) at least Plasti dip is a bit more flexible, and easy to fix.
