https://docs.google.com/document/d/1...t?pref=2&pli=1
After fitting the harness. I noticed that this. View on how to install the harness had removed the jack. Box ,
Those stupid fixing that VW. Use are a pain in the but. Impossible to remove , glad I didn't have to.
HELP. Today I had a friend attache his Ross tech cable up and Tick all the boxes to allow the trailer wiring. Got home attached the trailer and
The blinkers. Work. Stop lights work. But no tail lights .
I checked all the plugs. ,and I even plugged in my Navara ute and every thing worked ,
Did he miss some thing?
Any one got any ideas that might solve the issue. Thanks.
Solved the problem. Apparently the 13 pin trailer plug has two pins for the tail lights The 7 pin adaptor only connects to one now it's either pin 5 or 7
So I bought a 13 pin to 7 and now the tail light all work .
trunk lining removal
I have been looking around for some photos of how the trunk lining comes out so I can fit the module.
Does any one have any tips?
- You may not post replies
- You may not edit your posts
Forum Rules
